"Fishpaste" that was more of a sarcastic comment by me, not being rude (just a smart ass :P). Better is a really general term when comparing turbos or any component.
Better, but how? Is more what I was trying to get at.
"Fishpaste~" that was more of a sarcastic comment by me, not being rude (just a smart ass :)). Better is a really general term when comparing turbos or any component.
yeah, i could smell the sarcasim... :)
but turbo selection is such a personal decision i didn't want to put my bias into the "better" reasons, rather make people go read the information that is there. if you get what i mean
my personal recomendation would be read everything online that you can, but then go to your tuner and say "i want my car to do X, Y & Z, what turbos do you recomend?" and have a conversation with them about it all. lets face it, for the majority of people asking these questions their tuner will be the one installing turbos, setting up the car and would have done it 100's of times and know what results to expect!!
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
