  • Replies 650
so leave villis at say 6:30? give hour and half?
nah, i'd say an hour or so to get up there at that time of the morning, so leave Vilis at 7am at the latest. 20min from there to Grand Junction up South Road should be ok (+/- the Croydon train crossing)
I'll be bringing my jack and stands so we can definitely help Krishy out
ill bring car ramps :)
same, jack, stands, oil, brake fluid, coolant and demineralised water, etc etc etc, cars gonna be fair full. lol.
im sorta thinking 6 am at villis eat then leave around 7ish to get to lala? or earlier? dunno how long it will take?
ill park off next to the caltex (no im not filling up there) on pt wakefield and wait for yas. what time are we supposed to be there?
Krishy, we might be able to bleed your brakes at the track if we have enough jacks, i'll have mine so if a few others do we should be able to do it easy.
Thanks for that boys.....really shows the SAU spirit is well and truely alive...will let you guys know as to how things go
Krishy would u wanna do ur brake fluid at the work shop monday morning before villis?
Yeah thats a pretty damn good idea....thanks luke you have a PM
I will hang 10 with Damo at the same joint and join up as need be
I'll just meet ppl at the track, probably leave home around 6.45am to get out to the track around 7.50am
will bring 2x spare helmets, jerrycan with pulp + octane boost, 2L oil, some tools (incl. spring clamps) and can bring a good jack if needed too
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
