O.h Perfomance James Vosilaitis And Sonia Are Crooks
I bought a r32 gtr of this guy and the engine blew up. Then he rebuilt it and it blew up again. I told him I was taking legal action against him. Then he told me wouldn't give my car back to me until I payed him for stripping down the engine and he said he would give me the car back in pieces. A month or so later he rang my father and told him that my car had been broken into it had been damaged and parts had been stolen off it. Which included my front seats, intercooler, oil cooler, oil re-locater, custom polyurethane front bar, hks gauges, hks boost controller, front head lights, carbon fiber bonnet and the list goes on. It went to civil court and we settled on the condition he give me back my car with all my items that were stolen in the burglary. I went to pick my car up and he wasn't even at his work shop on mcintyre rd in sunshine. He had some kid there and the car was there but it was basically a shell. I refused to take it and it went back to court and he was ordered to pay me $500.00 which I have never received. Checkout the before and after shots.
everyone knows not to go there lol why in all the places you could of went to buy a car you went there lolz. you should have done some research before....but bad luck man and what you mean it blew up? what did? why? oh's fault? poor engine install/dodgy?????
James and Sonya are both crooks correct, I feel for you mate, he tried it with me too, many years ago. Its a fact he makes money buy rolling people. If you want the full story quietly let me know but its lengthy.
Thread lock in,
5,
4,
Edited by Takahashi GTR
Something doesnt add up here, you went to court and won but only got $500 ?
There is something you are not telling us... Otherwise damm this sounds like the best rort ever, fix somebodys 100,000$ ferrari, stooge them out of everything, pay $500 fine, sell parts for $50k.
Rinse, Repeat.
Never trust anything from the WEST....IBTL :D
Harass him tho, get nasty enough and hell prolly fix you up with anothee stolen/rebirthed car from one of your mates... :D
Locked.
Although given James own 'displays' & 'claims' on this forum about cars he is selling... which through investigation have been shown to be 'not quite' as advertised, I can't say I'm surprised.
Either way, can't have business slander going on.
Last word if i may... if he was ordered to give the car with everything, and then you went to court again and he was only ordered to pay $500 - that doesn't make a lot of sense knowing how the courts work myself having been through similar civil rubbish with someone i no longer live with.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
