"the 33 is where its at... but the 32 is quicker."
I believe this statement to be a myth. Having watched a stock v-spec 32 vs a v-spec 33 - the 33 is the clear victor.
In terms of equipment - r33 is a clear winner
In terms of aesthetics - the r32 is considered by many, to be far superior.
Personally, I'd take the r34 over both of them - but who wouldn't?
Originally posted by DaiOni
ps: I've read the import reviews too - but do they actually test a stock (vs stock) car?  hmm...
hey mate.. i was going from Nissan's production times... the '32 was/is the quickest of all 3.
Christian
I've driven all 3 GTR's 32, 33 & 34. Though the 34 is my preference. I think, for the money, the 33 is the best value of them all.
If you've ever driven the porsche turbo's, the 32 would be the 993 Turbo, plain & basic, rough, tough, pyschotic little spoilet brat. The 33 is the "Manual not the tiptronic" 996 Turbo, a few luxuries, smooth criminal, big, has a presence with a mix of Bill Goldberg & Al Capone. The 34??? we'll talk about that later.
**Also - this thing about 32's being quicker, hmmm?? Realistically speaking...it's not like you'll notice the difference between them all.
32 for me. Whilst the 32 is slightly faster in a straight line there is a greater difference once the road gets twisty. The 32 due to being lightler and a shorter wheel base has superior cornering ability. It is far more race car like in it's feel. It is and feels and lot smaller.
Mick.
I dunno...I used to like the R32 over the R33, but I'm not so sure now? The R32 does look tougher, but it's age is really catching up with it and it's not refined, looks out-dated but tough. The R33 is bulkier, smoother and more refined...but it's bulkiness can still look aggressive. I've never driven one, so I can't comment on their driveability...just from an aesthetic point of view.
I'm going to also go on the line and say that, stock v stock, the 33 will beat the 32 in a circuit race. Close but comfortably. The visual evidence I have seen backs that up (with different drivers, different course, result the same...)
The dynamics of the r32 may make it more of a 'pure' sports car (that's why they went back to some of the design elements with the 34 - wasn't a performance issue in any department). It is, from all reports, a more 'on the edge' car than the 33.
yea ive owned a r32
i would take the r31 with the gtr engine anyday
because all gtr r gay (doesnt take any skill to drive em fast)
mind you a r32 with the fuse pulled is alot of fun i must say but still no r31
Like this beast I saw hooning along to wakefield the other weekend. ;)
Gets the *** sik award for 03.
Guys the 32 is still the king. Not because it is lighter or quicker, but because it is the origional. Its like a trilogy movie, the first is always the best.
Plus its looks are timeless. whereas the 33 looks clumsy. sort of like a patch up job ;)
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
