Hello there i got a R34 gtt which is basically looking to stock for me . i looked at carmate.com and found this sweet ass looking front bar which is for the GTR. what i wana know is will it be a perfect fit to a GTT? i know ill probably have to find a gtr style bonnet in order for the bar to fit nicely but iam just unsure if the bar will fit onto the car.would you say i need to get wider fenders as well?
pleaase anyone who has done this conversion or got any info iam all ears cheers.
https://www.sau.com.au/forums/topic/286490-r34-gtr-front-bar-for-gtt/
If it's for a GT-R, it won't be a perfect fit as GT-R's have wider guards than GT-T's.
In saying that, if you really like the bar you can have it modified at any bodyshop who can work fibreglass.
I have a GT-R front bar on my 32 but I have a little experience with fibreglass and I modified it to suit.
If you have the will though, there is always a way.
Good luck on what you decide man.
only what i got atm,
ive readjusted it since and the gap to the bonnet has been reduced quite a bit.
Just like what they did in Fast & Furious 4...put OEM GTR front bar, sideskirts, wing and rear bar on a R34 GTT for the movie - it was actually a GTT as most of us probably know. However, it's the OEM stuff that makes it look tough.
  • 3 weeks later...
Actually they used an east bear masterpiece body kit on a GTT with GTR badges etc for the movie.
carmate = fail
carmate + fibreglass frontbar = EPIC fail.
Your choice. I wouldn't put a fibreglass frontbar on as they're too brittle ..it will crack first time you hit one of those parking bumps.
that's bs.. i got a fiberglass do-luck front bar on mine.. it's low as and i bump parking blocks (on occasion) and it also hits speed bumps (although i go over slowly... very slowly lol) and it just scrapes.. fiberglass doesnt just crack when it hits something.. unless you drive into it at speed. they have some give and i even hit my driveway coming in and going out (sometimes) and all it does is scrape, they still have movement in them..
and if you get any cracks in the bar (they are usually small and confined).. you can take them to get patched up fairly easy..
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
