can u make like a switch so that u can have rear wheel drive or all wheel drive in the gts4 32s
As far as I am aware you can, IF you pull the fuse out for the 4wd you will be stuck in rwd. So wiring in a switch may be a possibility... Not a bad idea as GTS4's are a pain in the ass to get off the line
https://www.sau.com.au/forums/topic/286544-r32-gts4/#findComment-4807901
Yes you can.
You wire an inline fuse to a switch and crimp spade terminals where the original fuse location is situated in the engine bay.
Just be aware that to get back into AWD, you have to flick your switch back and turn off the ignition to reset the feed.
https://www.sau.com.au/forums/topic/286544-r32-gts4/#findComment-4807926
to add a note, there are two fuses that will disable the 4wd. One in the engine bay that kills the power to the hydraulic motor itself, and one in the interior that pulls power from the control module (but this also disables abs).
I put a toggle switch on the motor feed, and a momentary on the module feed. Switch, burn, switch and push button and good to go. Don't really like the idea of turning off the ignition when you are meant to be staging. Toggle is good for when I want to play but still have abs.
Edited by heller44
https://www.sau.com.au/forums/topic/286544-r32-gts4/#findComment-4808752
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
