Intercooler ====> Boost Controller ====> Wastegate
Remove all the tubes you put at the back there and just use 1 tube going from the vacuum nipple to the BOV.
If there is a tube coming from the BOV return pipe, which used to go to the stock boost solenoid... stick a screw in it and block it off.
Edited by SKYRYAN
hey again guys, what i basically need to know is if its possible to run the controller from the manifold. i dont have any nipples on my cooler piping or cooler itself so the manifold is my only source of vacuume. the stock solenoid isnt fitted to the car. how ive got it there is manifold>boost controller>wastegate actuator with a T-peice going to the bov before the controller.
am i able to leach vacumme from the pipe comming from the charcoal canister? to run the boost controller or is that just a stupid idea lol?
Edited by XxNinjaxX
u cannot use manifold pressure as the source for ur boost controller, it must be turbo pressure, eg all intercooler piping between turbo and throttle body, get ur hands on a threaded hosetail fitting, drill and tap a thread into ur piping and use that as ur pressure source
Thankyou lol, finally the answer i was looking for XD any places i can get a hose tail fitting from that u know of?
It's really easy to tap a nipple into aftermarket intercooler piping, just get a small screw nipple from super cheap auto and then buy some metal epoxy. Drill a hole, tap the nipple and the epoxy the f**k out of it.
any place shoulde have them man
Try pirtek or couplers, they are normally pretty good
make sure the tap is the right size and thread pitch
the most important thing (and the obvious one) is make sure you REMOVE the pipe before even thinking about getting the drill and tap. if you leave any swarf inside that pipe then your engine WILL NOT like it lol
why not?
if you havent got any nipples on your cooler piping just plumb it up to the intake manifold, works fine
why not?
thats the point of this thread lol i tried that and its not working, ive seen a few people hook it up off the charcoal canister vaccume line and apparently it works?
i work at rotomotion, if ur after a threaded hosetail fitting we have heaps of them in house, or leave us the car and we will do all that for u and make sure ur boost controller is all functioning properly
Jonno - firstly boost controllers have a bleed off function, if u are hooking in ur boost controller into manifold vac uv just given urself a vacuum leak
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
