Last night cruising the lovely streets of Melbourne, we came across a nice white R33 GTR with the plates GTR-330.
Does this person visit these forums?
We were curious as to what the 330 stand for. Does it stand for 330rwkw or rwhp, 330kw or hp at the fly or is it simply coz the car was a R33?
https://www.sau.com.au/forums/topic/28679-gtr330-anyone/
Originally posted by Jamezilla
Oh - and it has a 3-litre kit with N1 turbos. Perhaps this lends more to the 330 being kw :)
Would that be 330rwkw or 330rwhp and either at the fly or wheels??
I'd want to see that to believe it. I have my reasons.
https://www.sau.com.au/forums/topic/28679-gtr330-anyone/#findComment-592701
Originally posted by R31Nismoid
Reasons?
HHmm...
/sniffs the air
I personally saw it get owned last night by a GTR with 310rwkws.
The launches were both pretty good but the other GTR by the end of second was a bout 3 cars ahead. No braking was involved until the red lights ahead.
https://www.sau.com.au/forums/topic/28679-gtr330-anyone/#findComment-592728
Leewah , and others, this GTR330 is a customer of BMT. Its owned by a guy called Desmond who bought this car off another guy who had previous work done on it by us. It hasnt got 330 at the wheels. Its a 33 thats why. It aint that quick, but its very tight and tidy. mad Diamond audio install, nice wheels...and around 230 rwkw at the moment. Lets see how its goes in the near future...maybe he might have enough balls to step up to the plate with the big boys soon.
Later boyz .........
Damian
https://www.sau.com.au/forums/topic/28679-gtr330-anyone/#findComment-594293
Yeah , i do agree that its a clean car.... but i guess most cars would after a full respray. I should sell him my T78 turbo kit and cams, and then we should see well over 330rwkw. Then his plates would be justified. Just a quick one, have you had any dramas with your Giken gear set? Because, as you maybe would have heard, a few months back, i broke 3rd gear in my 32 with a full giken gear set. Not happy. Thinking of a Schifzer or Guru cross gear set. What do you reckon, because for you to pull 10's with that box and not breaking anything... i want to know why i did. I was changing at 7800rpm only, and it shattered all of 3rd. Looking at a gear set or complete gear box..... you know anyone with any of these combos. Because, i aint prepared to shell out 7-8 grand for a brand new one, or 12-20 grand for a dog box.
https://www.sau.com.au/forums/topic/28679-gtr330-anyone/#findComment-594453
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
