ive now got a leaky abs unit
freind checked it out and advised its the abs unit................
i want to either
1.send it to an expert for repair - who would that be???????
2.remove it and turf it out (ive searched) is there a gtr without abs? if so i will purchase the non abs gtr lines etc..
any answers will be much welcomed
as im to scared to drive the car now since the brake fluid went to low and i had no brakes
and i dont want to go there again :)
https://www.sau.com.au/forums/topic/286793-abs-issues/
lol dude, fill up the brake fluid and ull be ok
take it to any brake specialist and they can fix it for you, i think its illegal to remove abs if the car came fitted with it, plus why bother wen it could save your life.
take it to a brake and clutch place
or
go to a jap wrecker and get another one, then take it to a pro to fit it
or
go to nissan and they can fix it for top dollar
https://www.sau.com.au/forums/topic/286793-abs-issues/#findComment-4810920
  • 1 month later...
Abs is now removed
now time to dispel the myths.......
1.Car drives fine
2.Attessa works fine
3.There is an ABS light on the dash
4.4wd Engages as per normal
5.Nothing has changed at all
time for pics
Before..
After....
Edited by DAS KAMU
https://www.sau.com.au/forums/topic/286793-abs-issues/#findComment-4872988
  • 6 months later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
