Obvious:
RB20DET
6 cylinder, 24 valve
2L
RWD
5 speed manual
Exterior:
R33 wheels
NO rear spoiler
Interior:
Autometer Phantom boost gauge
Razo:
turbo timer
gear knob
pedals
JVC cd player
Sony Xplode 6 inch rear speakers
Engine:
R33 (series I) turbo
3" custom turbo back exhaust (including dump pipe, CAT, resonator and muffler - all 3 inch)
TurboXS bleed valve (13psi)
TRUST panel filter in standard box
ARC Side mounted intercooler
Brake booster Brace
Polished Rocker covers
Strut Brace - Front and Rear
GTR fuel pump
All the little things:
100,000km service done at 93,000kms (I have a $1800 receipt for that)
reason for the high cost is a few extra things I did.
*All new polyurethane bushes.. Upper and lower front and rear bushes.
Not cheap at all.
*New 2 core radiator
*Redline gearbox oil
*DOT 4 brake fluid
*new diff oil
*new clutch fluid
*New engine mount
Along with new timing belt, water pump, radiator hoses, other belts, spark plugs, injector clean, fuel filter, oil, oil filter.... the list goes on..
Car is currently at 98,000kms
Interior is pretty damn good.
Exterior is pretty good for original paint except where I was badged and the drivers door has a few chips...
Tyres are 235's on the back and 225's on the front (look a little chunky on the standard R33 rims but they grip really well)
Currently has 153rwkw.
a re-mapped chip should bring it to about 170rwkw and cost you about $200.
I might still do that if it doesn't sell.
All recent pics can be found at http://www.pbase.com/the_r32/inbox
I will NOT separate anything.
I will NOT swap for anything...
$16,500. - NEGOTIABLE
Sydney Only.
https://www.sau.com.au/forums/topic/28689-fs-r32-gtst-silver-16500-sydney/
    • It's been quite the ordeal but hey, at least you figured it out.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
