Ok so i spoke to a mate of mine who is a mechanic he said that a scremer pipe will increase boost response time because the turbo keeps spooling/spinning somthing about there being no back pressure. can someone confirm/deny this because this would be a performance increase.
i would like to get into drift raceing i just dont have the money but little things like this i can get made up and use them when i start drift raceing and remove them when i wanna drive on the road.
the effects will be minimal over a decent exhaust with it all plumbed in.
well i have a full 3inch into 4inch cannon from the turbo back would you consider that a decent exhaust?
Edited by R33Gtst Driver
planing on doing it with the stock turbo? if so you will still only get 200kw and 3" will be fine for that and it should still be fine at 300kw.
i have a high flowed t3/t4 turbo already but im planning on geting a g35? turbo i thinks its called i will be makeing 4-500kw or more for now i think thats what my mate is makeing im pretty much just copying what he has got
no gt35 is going to give you 4-500kw. it is not a turbo capable of that and your engine wont like it either.
yeah im not sure about the name of the turbo im pretty sure my mate said it was a g35 turbo he is using? allthou i cant find any info on it so i probley have got the name of it wrong
Edit: also i ment hp not kw
i think this is the one he has http://www.cimotorsports.net/motor-sport-p...rbocharger.html or something similar. so what the reason my motor wont like it?
The stock engine internals are only so strong, you are asking them to deal with 200kw or more than the factory 187. it may last for years it may last a week.
i thought you were gonna say it wasnt big enough :cool: thanks for the heads up but im aware of the internals factor im not to worried about it thou as im planning to build a stronger motor anyway
i just realised this would be a good place to ask a question so here goes basicly i wanna make 600hp - 1000hp in my skyline with a really good response. the responsiveness is more important to me then the power but i would still like to have a alot of power what turbo and engine mods would you guys suggest? i have been looking at turbos from here http://www.turbobygarrett.com/turbobygarre...ers.html#medium but i cant make my mind up any hlp would be apprecitated
at no point should you combine i want 600-1000hp and response is important. its not going to happen. 600hp is getting to the upper limits of a 1.0 rear T04Z and thats not going to be on full boost till 4500-5000 or later.
ok well i dont know much about what im doing wwith upgrades. i just want huge amount of power and a decent spool time i figured big lag and nos shots were required for 7-800hp or more.
whats the to4z hp rated to? as thats sounds good to me and am i better of going for a cutoms turbo like gt35/gt42 or gt45 over a t04z
The circuit car that im driving is a 32 v-spec gtr v-spec, fully built engine and drivetrain with a custom t04z external wastgate/screamer pipe.
Puts out 420awkw at 1.5 bar, makes the best sound in the world. I really think you need massive power to make an screamer pipe a worthwhile/credible thing.
I havent fully read your thread, but i cant help but thinking your modifying the wrong car. The to4 on the rb26 has a significant amout of lag, starts pulling from 4300 and then rockets from 5 to 9,000rpm in the blink of an eye!
Wouldnt have much of a rev range without massive cams and strong internals.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
