Yo
Did my swaybars today, can I just say what a MAJOR difference the car feels to drive now, feels just like my old 350z now to drive handling wise which is a good thing :P
I've never had the pleasure of driving one, but if the V35's are anything like the 36 then they must suffer a bad case of understeer?
If you've been thinking about them but holding off I definitely think they're a worthwhile upgrade
corners that I used to have to fight the steering wheel (under under!) to get around are now taken with ease, the car feels precise and stable, where I used to make minor steering corrections mid corner/roundabout and the wavy boat feeling has disappeared.
I have noticed the car feels harsher when entering/exiting driveways and speedhumps but I'm not complaining
I wish these had arrived in time for the texikhana that just passed, no joke I would've done a whole lot better than I did on the day :)
just thought I'd share some pics, eibach lowering springs go in tomorrow!
fresh of the boat
plastic undertray had to be taken out
is there anything WD40 CAN'T do?
the difference between understeer and fun
this little bastard cost me nearly an hour :)
time to hit it from the back
had to unbolt the exhaust to get the bar out
side by side
tighten everything back up an voila
more pics to come after the springs are in >_<
https://www.sau.com.au/forums/topic/287538-installed-my-swaybars-today/
wow....well done Yo! looks crazy man... just a quick ?. did you buy rear camber kit aswell?
hey, I was going to depending how the springs went and alignment after installing everything, thankfully they were able to get everything into spec without needing a camber kit :)
nice!!!
mind telling how much those set you back and where to order them from??
Hey mate I had to source them from the US, set me back $320 for the pair and shipping was almost as much as the bars themselves :P but money worth spending considering the end results transformed the car completely for the better
looks good , what size sway bars?
don't have a clue to be honest, they say it stiffens up the rear by 30-60% depending on the setting you choose
+10!!! haha
i've got my nismo swaybars installed as soon as i got my car! very worthwhile upgrade!
I know aye, wish they arrived sooner lol
Okay springs done today, decided to get them done by professionals, don't have the skills or the tools to tackle a spring install
big thanks to Wholesale suspension in Penrith for the install and Pat for fishing my stock springs back for me after I left :)
springs need some more time to settle so they're still due to dip a bit more
before
after
before
after
lowering looks hot too , how does it handle now?
i guess only time will tell if there's any camber wear, is anything fallible to correct this for v35/v36
yeah adjustable camber kits are available for those who are absolutely anal about tyre wear, but the shop that did my springs were able to get camber back in line at the front and about -1.4 neg. camber at the back = happy sideways times
Nice drop! I'm glad you didn't paint your wheels black like you intended to ...they look good as it is.
hehe, who said that? :) :) cheers buddy
the springs were a good choice, I tried driving around a shopping centre with notoriously high speed humps and I only scraped on one, and even then it was only the black plastic lip/splashguard under the car, this may change once the springs settle though so I'm hoping they don't drop too much more
Sup SKy,
what does WSP specialise in service?
WSP is a one stop shop for your suspension needs. They sell products but they also have a 6 hoist fitting and service area.
They build suspension parts to cater to all vehicles.
If anyone is interested in upgrades or full alignments i would suggest attending their open night on the 23rd Wednesday night 7pm
Free BBQ and lots of man talk!
Ill be there with the R33 :)
Yep pat helped me out :bunny:
I was impressed with wholesale suspension's setup, I used to drive past that place everyday to get to work but never been until now
I've toyed with the idea of spacers but I'm suss on using them even the hubcentric ones that also use their own bolts, but that's just me I guess... aren't they a defect?
don't really want to buy aftermarket rims, doesn't suit what I want from the car
cheers
cheers, the springs are eibach pro
I may still paint the wheels black, they are stained from when the dealer washed the rims after using tyre shine so there's black streaks stained into the rims that I can't wash out I'll either paint them black or shadow chrome
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
    • I've got three stashed away but it's starting to get silly with the prices
