Hey guys i just purchases a skyline r33 gtst, new to the whole turbo thing. am i better to stick with the stock air box and customisw the intake so it gets direct cold air flow,or replace it although ive heard the others can cause ur car to intake hot air and loose performance?
also wat should psi should i be running the car at? i have it running at 20% on low so im guessing this means 20% of the standard psi which is 8 this would mean 20% of 8 = 1.6 so 1.6 + 8 = 9.6 psi is this correct? and if so wat % should i be running it at on lo and hi? low being for everyday use
thanks guys
https://www.sau.com.au/forums/topic/287560-help-with-atmospheric-bovs/
thanks guys
Stick with standard airbox...
Max boost for a standard turbo is about 14psi before it goes BANG
Safe boost is more like 11-12psi.
Heaps of topics on these subjects...
I suggest reading the FORCED INDUCTION section of the forum :whistling:
Happy trails
Hey mate, like Joe suggested have a good read through the forced induction section, and try searching for some specific phrases like 'safe boost'.
I'm assuming you're using an electronic boost controller, so you can set a low boost level, and a high boost level? I'd have low boost set to 5-7 and high boost about 10. I run 9.5-10 constant on mine, just to be safe. But like everyone will say, about 11-12 is considered the highest you'd want to push a stock turbo frequently.
ok no worries guys thanks, it doesn't have a stock air box in it atm its currently got a after market one but from what Ive heard they just suck in hot air and cause Ur cooler to work harder is this true and if so should i just replace it with a stock air box and ebay the after market one?
also my boost controler shows % does this mean its % of the standard psi which is 8, is that correct? therefore if i set it to 30%, it would be 8 + (30 % of 8 = 2.4) so total psi would be 10.4, is this correct? and sorry guys just new to the whole turbo scene.
any tips on to keep it maintained or mods to start with would also be greatly appreciated
thanks a lot mark
if it is an aftermarket airbox then it will be fine and will be an improvement over stock. if it is a pod, then still use it. i am of the opinion that a pod sucking some hot air but flowing enough air is better than an airbox that is only sucking cold air but is choking the engine up top.
also, before you do anything else. go and buy a boost gauge. and i mean right now. depending on how the controller works, being at 20$ will probably mean that the solenoid is working at 20%, not that you are getting 20% more boost. so depending on the power of the solenoid, 20% could be 0.5 psi (meaning you are running about 7.5psi) or it could be 5psi (meaning you are running 12psi). so go and buy a boost controller before you do anything else, and take it easy on the way there. even if you only buy a cheap $50 drift one it will be better than nothing.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
