  • Replies 85
Posted Images
How much for the 4 brake rotors only?
Thanks
Hi only have the rears remaining....
Hi bud im after some parts for my skyline if you got them, I need drivers side Blinker on the guard, indicator switch on the steering column, (series 2) and also I need the surround on the window switch on the drivers side door, Im in sydney too how much for these items, Also if you got a good clean radiator shroud I might take that too cheers, 0422992242
pmed you mate.
Hi SAU
Decided to wreck my R33 s2 and not repair after a side on.
This car was in mint condition with 93,000klms.
So here is the list: By all means PM me if anthing your after is not listed.
R33 gtst s2 Complete 93,000 klms engine $2000
R33 gtst s2 gearbox $1600
ECU to engine Harness $220
ECU $150
Radiator $150
K SPORT height and Damper adjustable suspension $1000 (less than 5klms near new)
Air filter with adapter $80
cat back exhaust $350
front bar complete with foggies $450
front guard lhs or rhs $100
bonet r33 s1 in black $250
RHS R33 s2 headlight $280
front grill $150
front reo bar $220
rear bar $120
m spec side skirts $150 pair
m spec rear pods $120 pair
Door $150 each
Mirrors $80 each
taillights $90 each
Skyline rear garnish $60
boot lid $100
s2 rear spoiler $100
brake light $60
GT badges $55 delivered pair
Front m spec lower lip $150 couple cracks in plastic
Power window motor with regulator $150
Power window Drivers switch $95
front seats $300 pair complete with rails
rear seat $150
Door trims $90
s2 Steering wheel with airbag $270
rear parcel shelf $90
r33 s2 gear surround $90 very good nic
Drivers PW surround $90
climate control unit $90
Complete 5 stud setup $1000 (Will separate bits; PM me).
Lower control arms $100 each
Front hubs $120 each
Hand brake cables $150 pair
Front rotors $100 (near new)
Rear rotors $90
Front Calipers $350 pair
Rear Calipers $250 pair
LOCATED SYDNEY: HAPPY WITH PICK UP OR DELIVERY AT BUYERS EXPENSE.
ANY BITS NOT LISTED PLEASE PM ME. :D
Im located in sydney
interested in dash surround, gear selector surround and plastic mould under steering wheel
sms Manny 0406747726
Hey Hey,
Just wanted to know if the following parts are still available and if you could please send some pics or wherabouts you are located so i can come have a look.
1) Front m spec lower lip $150 couple cracks in plastic
2) front bar complete with foggies $4503) RHS R33 s2 headlight $280
4) front reo bar $220
Thanks :D
Hi SAU
ECU $150
Radiator $150
front grill $150
front reo bar $220
rear bar $120
Door $150 each
Mirrors $80 each
taillights $90 each
boot lid $100
brake light $60
rear seat $150
Door trims $90
Rear rotors $90
ANY BITS NOT LISTED PLEASE PM ME. :blink:
  • 1 month later...
  • 3 weeks later...
hey mate i cannot pm u as have not got 10 post how stupid but will take the grill condenser and headlight for that s1 33 delivered to bundaberg so if you wanna send ya phone number ill give you a call and get ya bank details of ya thanks man
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
