Hey guys, due to a front end update, I am selling my existing stuff.
Would like them to go all at once.
Ideally it will be pickup, but I can ship at additional cost if you need me to :P
Factory Xenon's. All globes included - 4300k D2R xenon, H4 high beam, SMD LED parkers (white) and yellow indicator globes.
The lights do need the rear cover and indicator globe plug (Nissan part #26243-AQ000)
NM35 front bar and grill
Will obviously be cleaned before handing over/shipping.
There are some light surface scratches but generally in pretty good condition.
The rubber lip is in good condition with no broken tabs.
The grill also is in good nick with no broken tabs.
$450 the lot.
Edited by iamhe77
https://www.sau.com.au/forums/topic/287879-m35-stagea-front-bar-grill-xenons/
  • 1 month later...
Just out of interest, do you have any pics of the new front end your changing to ??
Yes.
I originally bought this PM35 RX front bar
But I will be looking to move it on as well due to me buying an Autech Axis S front bar (in my avatar)
Yes.
id be keen on this.. :( what's the move it on price ??
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
Hi
What type of new front did you install, did you have to export it or did you buy the new front here in Aus
im looking to do some upgrades, and im looking at all the options. my brother is in japan and heres getting me the prices of the nismo badges from nissan
thanks bryan
Hi
thanks bryan
Hi Bryan,
I purchased an Axis S front bar and a 2006 M35 bonnet via Import Monster to continue my conversion (I still need a grill :no: )
It will not fit on an ARX or normal Axis due to their flares.... although they can be removed.
Here is how it looked before I meshed the lower intake spacers (black mesh of course) which made it look much, much, much better.
Edited by iamhe77
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
