sorry for the late reply
i got the brakes running in now
so far done abot 300kms on the weekend
overall impression feels like im driving my evo again when im punching the brakes lol
pretty damn good
pedal still feels abit abit too soft but doesnt feel dodgy though
ill wait and let my bank account recover and spend more money on it later
how much pedal movement before you get them to bite?? more than the stockers i would imagine!
when you buy the new master, make sure the outputs are in the same places as the current one
  • 1 year later...
Sorry to res this thread - but I've got the 350z brembos and want to get all the parts I need before fitting it.
So far, I've got the calipers. I'll get rotors and pads locally.
I've seen the master cylinder on ebay. Does all 350z have the same master cylinder or would brembo equipped z33's have different ones?
Also, brake lines from 350GT needed?
Too bad Danny doesn't come on the forums anymore...PM'ed him but no response >_<
I have Brembo's and my brakes are perfect....you don't need to upgrade the master cylinder.....you will have hassle's fitting the standard wheels though.....you use your brake lines.
P.S. Danny sold his car about 1 to 2 years ago....went to an IS250 or something.pinch.gif
Hmm I'm planning on running 350z Track rims. 18 x 8 +30....would they clear?
Either that or GTR rims...18 x 9 +30....
Hi all,
I've just purchased from the US via ebay a full set of brembos from a 2005 350Z anniversary edition including brake lines. Shipped Monday via UPS. Three boxes in total. One box weighing 45lbs containing the calipers and 4 rotors in 2 separate boxes each one weighing 40lbs. There is a new set of ceramic brake pads included and the existing pads have about 2K on them. According to the seller, all in excellent condition.
I've got Advan T7 18" wheels so should fit with no problems.
Now just got to find the time to install them. What with the sway bars and links from Daleo also. I've got some busy times ahead.
Rosella.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
