hey if the cops went nuts with the defects on the cruise it would be on today tonight :cool:
yes it would be, they would say that the reason they have those stickers is because they are illegal and unroadworthy and are a danger to everyone on the road.
There point has been proven, they look like the good guys and we look even worse, lets face it the people they aim shows like that at are not usually the ones who like to hear both sides of the story, they just like to be spoon fed.
  • Replies 279
And every state to get involved ...... seeing I'm from Sydney.
We just need the right people to organize it.
Sorry guys just an off topic question. I noticed on the tv show they pointed out the pod air filter and that being illegal. I was too fined for my pods. but when I ask why I get different answers, from noise pollution, a fire hazard, back fire hazard, and last exhaust pollution by running richer.
Are they really a problem?
+1
I'm very sceptical in working with medias like TT/ACA in trying to make import drivers look anything but 'hoons' to the general public. If anything TT/ACA will probably twist & edit the story around & make you guys look even worse in another "hoon" story its not the 1st time they have done it, anyone still remember the "drifting hoons in Sydney" story they did with footage of people drifting in Japan.
Depends on the state, in WA open PODs are legal (last time I checked) as long as its secured properly, however having said that, if the cop wants to sticker you, he still will. :(
In vic its because of power (in my mind) you are allowed to have one intake mod, to me it is to limit the amount of power you can get, the general rule is that the airbox is good for 250rwkw and i have heard or people getting 300rwkw with the factory airbox so i dont understand where it is the first mod people do.
i thought its an epa issue because of oil based pod filters ? most police leave u alone if its boxed in anyway.. doubt it would be much of a power issue as people pull good figures with factory boxes.
Oiled filters are illegal due to epa, non oiled ones are legal as long as they are the only intake mod.
Any cops on here??
Im sure that when ever a cop takes someone in that they have to search them before being put in the car, that drunk guy in the ute was put in a car with no divider and obviously not searched before they left other wise the cop would have found the wallet in his pocket, also its obvious that the cop didnt search the car either, maybe if the dumb f**k had done his job properly he wouldnt have been there after his shift ended.
So.... What your saying is that you want the police to search you every time you get a ticket, search your car and assume your lying to them? All this to prevent some overtime for the cop... The cop had to take him back to the station anyway to give him a breath test..
wow i'm even more confused about the pod air filter now. two weeks ago I was pull over and the cop looked under the bonnet to see a box around my pods. So he said thats fine. I did ask him why I have to run a box and he said it's because of oil and grease build up of the filter makes them a fire hazard .
If it's true about the epa then seeing mine is a personal import and I'm exempt from emissions . That is what they told me at the RTA.
read my post again and then make another comment.......
Should have a cruise for "Skyline owners against police discrimination" and get the media involved..Show people the other side of the story.
if you do that, make sure all the cars going are all Road worthy and non defectable or can get EPA's otherwise, you just add fuel to the fire ....
My car is now 99% roadworthy, just need to get a new midmuffler welded in and that should drop the exhaust below 90db.
I reckon you could count on one hand the amount of cars on this website that are roadworthy and undefectable.
I've got a friend who's a cop and he tells me that the TMU guys are trained to be able to defect a car that has just rolled off the showroom floor. Isn't that crazy? With that in mind, i'm sure they'd be able to find something, no matter how insignificant, after all, that's what they're TRAINED to do.
btw, does anyone know the legislation surrounding pillar mounted gauges?
Interested to find it.
Just the fact that they can do you for a loud exhaust with no testing done to prove it means they can defect anything at will.
I looked this up a while ago, i believe from what i read on the vic roads web site that it comes under the same rule as bonnet scoops, which i believe is that you must be able to see the road 15 metres ahead of you from any adjustment of the seat.
i had two gauge holder got pulled over they told me its a defect if the gauge is above the steering wheel hieght.. having said that the guy let me go and just said make sure i move them :D
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
