Well, seismologists/vulcanologists predicted another huge volcano eruption is long overdue in Australia, by about 2000 years overdue...
Prior to this, we had an earthquake that was centerred in korrumburra, (gippsland)
and then there was this earthquake in Java and Bali...
the whole volcanic belt in Asia Pacific is going active from its slumber, it's all linked together...
https://www.sau.com.au/forums/topic/289063-earthquake/#findComment-4840520
felt it in hampton park. was really wierd, was like one hit, almost like a quick explosion going off in the distance, then the same thing again like 10 secs later. thought somebody was outside trying to f*ck with me so ran outside amped as shit, then was greeted with nothing lol
https://www.sau.com.au/forums/topic/289063-earthquake/#findComment-4840598
haha! wayneo! how are ya mate?
Berwick, where the hell is that?!??
The last one i felt in Berwick around February, i thought the world was coming to an end it was so unexpected
LOL
Hey.. Big fella
What you doing stalking the SAU forums ?
https://www.sau.com.au/forums/topic/289063-earthquake/#findComment-4842813
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
