  • Replies 40
ATTENTION
anyone know what sort of side skirts are on the above attachment: r334d1.jpe (posted by skyline_boy)
please help!!! i want these side skirts..............
They look exactly like what is on mine.... even thought it is a 32 looks identical!
It came with them from Japan so not sure of the exact brand but I will have lok for any markings on it tonight that could be a clue...
https://www.sau.com.au/forums/topic/28914-4-door/page/2/#findComment-599534
4 door 400r side on.
has any one seen one of these on the road? in australia?
400R front and rear GTR sideskirts, I have the same kit, but not fitted yet, it appears that you can't get 400R sideskirts for the 4 door.
https://www.sau.com.au/forums/topic/28914-4-door/page/2/#findComment-600356
from the initial post to this thread
looks like this one to me but i could be wronghttp://carpoint.ninemsn.com.au/marketplace/UsedCarDetail.asp?ID=2375783&Criteria=%40Make%3D%27NISSAN%27%2C+%40Model%3D%27SKYLINE%27%2C+%40ageMin%3D%271998%27%2C+%40ageMax%3D%272003%27%2C+%40OrderBy%3D%27P2%27&NoOfRecs=18&PageNo=1&chkRows=500
https://www.sau.com.au/forums/topic/28914-4-door/page/2/#findComment-600506
Well im going to email the japs tonight, I hope they can read english otherwise i'll have to translate english to japanese.
Why do you want side skirts when your 4 door is for sale???
Ive got a bigger pic of the car.
skyline_boy
it would just be nice to complete the whole body kit before i sell it, just to have the satisfaction that i know it was done. body wise, Skirts are the only other thing it needs.(and it would be nice to have a carbon bonnet, but not to worried about that).
here is a pic of my 4 door
https://www.sau.com.au/forums/topic/28914-4-door/page/2/#findComment-603156
I got an email back from the japanese garage. Ive got the site where they sell the side skirts. They're called aeropalace. I think they are 40,000 Yen which is around $504 AUS.
Aeropalace
you might need to use altavista's babelfish or something to read it because its in japanese.
https://www.sau.com.au/forums/topic/28914-4-door/page/2/#findComment-603286
oh and I love the look of your car
What is the legroom like in the back comapred to the 2 door??
thanks skyline_boy
the leg room is better then a 2 door but not buy much, just enough for the passengers in the rear to be comfy.
the main thing is convenience with the 4 doors cause when u take passengers there is no need to tilt ur seat.
i will have a look at the aeropalace site now. thanks.
https://www.sau.com.au/forums/topic/28914-4-door/page/2/#findComment-606012
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
