Guest darrinspencer
What brand are the short shifters and price.
Are these for 32 or 33 gtst, gtr?????
HEy everyone,
I can do a group buy on quickshifters and adjustable castor rods may also be coming up shortly. Just wanting to know what sort of interest there is to know whether it's worth doing a group buy for it.
cheers
jayson
ok the shifters are dead replicas of genuine c's short shifters. Still waitin on confirmation for rb25 btu i know they can get them for rb20det 2 wheel drive. The 4 wheel boxes may be slighty different. I only quickly visited the company the other day to find out if they had anything more coming through and to buy some parts for my car. Will be back in by the end of the week to get more info. The adjustable castor rods are also copies of a particular brand which i can't remember. I'll find out by the end of the week though when i go back.
By the end of the week i will have group buy prices for the quick shifters but the castor rods are still in production etc so will be a small while yet.
I will be getting a quick shifter for myself so providing you are capable of driving a manual car with a heavy clutch your welcome to try my car if your in brisbane. I've had a fair bit of interest from the nissansilvia boys too so the quickshifter group buy will go ahead. Strutto i think they'll make them for all skyline models cuz i think they'd be silly not to. However, i haven't sussed it all out yet but i'll be in touch.
Cheers
Jayson
Cheers
Jayson
Thanks buddy,
Let us know once you find out more...
an adjustable castor rod adjusts where your wheel is positioned. ie front or back in the wheel arch. It's apparently best to have both wheels forward at a reasonable position. Adjustable castor rods allow you to adjust the castor so the wheel can be moved back and forth. Does anybody have any more to add? I found out today that the castor rods will be available at the start of january so i'll bring it back up then when they come up due to the interest. I really need these also as mine is way out of align.
Quickshifters are available now for rb20det rwd at $240. Can post interstate and im sure postage will be under $10 for most places. Also available for s13, s14 and s15 ca and sr with the 5 speed box only. I will make a new thread in group buys now i have definate prices.
Anymore questions don't be afraid to pm me. Strutto will keep everyone posted on the castor rods.
thanks
Jayson
Best way I've heard castor described is by thinking of a wheel on the end of a stick (like a measuring wheel)...
If the stick is upright, and you turn the stick whilst rolling the wheel forward, the resulting change in direction is very sharp.
If you lay the stick back towards you, and then turn the stick whilst rolling the wheel forward, the resulting change in direction is more controlled.
Adjusting the angle of the stick to the ground is what adjustable castor rods allow you to do....
  • 5 weeks later...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
