Hi guys
Just bought an ACA Universal O2 Sensor (3 wire), just wondering if this is the write one for a GTS-t? i'm pretty sure it is, just want to make sure.
Also, best way to fit? wack it straight in or is there somethin else i should do first?
Cheers
Cam
https://www.sau.com.au/forums/topic/289568-o2-sensor/
i cant tell you if it is the right one without seeing it or a part number. but the one i got to replace mine '32GTS-T was a direct fit for an EL falcon.
3 wires, one was shielded and the other 2 are positive and negative. the shielded wire goes to the ECU signal wire. it comes with the wrong plug but i picked up a 4 pin plug from supercheap and re wired it in. easy and neat so i wasnt joining wires together. works mint.
https://www.sau.com.au/forums/topic/289568-o2-sensor/#findComment-4849110
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
