Hi guys,
Trying to locate a wiring diagram for the Series 2 Stagea that also displays what colour the wires are that come from the ECU. I have the pinout diagram which claims its for both Stagea and R34, but they plug is slightly different enough to give me doubts. I need to know the correct colours of pinouts 5, 23 and 54. I have a few gauges to install.
I only have an R34 pinout diagram which claims to be for the Stagea also. But it appears my S2 stagea is slightly different, ie pinout 22 and 23 neighbour each other without a separator, whereas in the pinout diagram it shows they are separated.
Help please, asap :laugh:
https://www.sau.com.au/forums/topic/289687-stagea-wiring-diagram/
Hi guys,
No doubt you've squirrelled through this lot? In DIY Stagea ecu blurb. Plenty of names to contact if info not on pdf.
Cheers GW
Quote < Hi guys as Darrin said there are at least 3 pin outs for series 1 W34 stageas. More details including how to identify by date and model code on ECU are in this thread:
Looks like the earliest ones are a very close match to R34 GTT. >Unquote.
http://www.skylinesaustralia.com/forums/R3...S1-t205298.html
PS: Not that this means anything but I have not seen any color coded diagrams, only numbered. Best thing to do in that case is bell out points of interest, 5, 23, 54. A/T input sig, Knock sensor, un-assigned. If you are looking for the following, on another diag I have; 38/Throttle sensor sig, 27/mass air flow sig, 7/tacho sensor sig. Or (your diag most likely.....R34) 5/Tacho drive sig, 23/Throttle position sensor sig, 54/mass airflow sensor sig.
PPS: My R34 pinout diag shows minor divider between 22/23 also.
Edited by 260tech
Yeah its that minor divider that is throwing me out (between 22/33 and not 21/22 as my Stagea is showing). Want to ensure that what I think are 5, 23 and 54 are indeed 5, 23 and 54 from the R34 pinouts.
My S1 Stagea pinout shows
pin 5 as tachometer Drive signal W/B
pin 23 TPS signal R/L
pin 54 MAF signal O/L
no idea what L stands for
I'm sure S2 are different. Should be (from what I can ascertain):
pin 5 is yellow/black
pin 23 is green/black
pin 54 is grey/blue
pin 5 as tachometer activation signal
pin 23 Throttle sensor signal
pin 37 Throttle opening signal
pin 54 airflow meter signal
pin 55 airflow meter earth
The problem is that the S2 pinout diagrams I have downloaded are claimed to be similar to the R34. But they're slightly different. The S2 pinouts are slightly different to the R34 pinouts and therefore I need to ensure the coloured wires for 5, 23 and 54 are indeed what I'm going to tap into! But nothing, NOTHING has the colours labelled. And everytime I look up a S2 Stagea wiring diagram, they give me an R34 diagram. Which is not the same.
Well I can't believe it.
I cannot source from anywhere a correct ECU pinout diagram for the series 2 Stagea. All references lead to the R34 pinouts which is incorrect.
Nissan themselves have nothing???
Not going to bother if I can't be 100%.
Trying to give my 2 cents...
check this 2 treads...one shows a fast and the other shows the pics of 2 Ecu s (one is the same number as yours)maybe contacting those members you can get any idea...
http://www.skylinesaustralia.com/forums/Pi...0&p=4785101
http://www.skylinesaustralia.com/forums/St...rs-t285701.html
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
