so i bought my 6 boost manifold ( high mount rb25det ) suited for a gt3076r ....i have started running short of funds so i thought i would just chuck back on the old t04e ... the side of the turbo is slightly touching the rocker cover.... slightly but enough to rub..... will one go through the other?? could i grind away a little on the t04e??..... god dam this is frustrating!!!
What about using a 10mm spacer between the turbo and manifold?
nar. shel be right.
if you want to be creative take it for a thrash and get it cherry red and use a tyre leaver between the FLANGE and head. (not the housings) a gentle leaver should give you a mm or so..
nar. shel be right.
hahaha creative i like...unfortunately she is in need of a mass tune so i think thats out of the question...... the 10mm spacer is a good idea....where do i go to get such a thing??
would u have to put a gasket either side of the spacer??
yes you'll need a gasket either side.
Any turbo shop will be able to supply the flange, even an exhaust shop (a good one) should be able to supply one. It the same thing they use for the flange on the manifolds.
any good turbo/exhaust place should be able to get you a flange/spacer. but if you have no luck try mtqes, they have everything you need
Edited by JonnoHR31
