Hi all, its me again with yet another plea for help. I'm hoping someone in the SAU community can help me out.
I have dropped my motor (from k frame) just to be able to remove/work on engine with ease. I am trying to separate the engine from K frame at the moment but I am having issues removing the front LHS shaft. Just wondering is there a trick to removing it?
Below are pictures of the shaft in question.
2725004050064171239GzawSb_th.jpg2922881790064171239vsbBER_th.jpg2549783640064171239eQzwKZ_th.jpg
Any advice/ help is much appreciated!
https://www.sau.com.au/forums/topic/290047-gtr-front-shaft-removal/
is that your driveshaft (ie have you got it out that far)? If not you pop it out by taking off the front diff cover and levering it from inside. Detatch the bottom ball joint and sway bar link to swing the strut out for the driveshaft to have enough room to remove it. Hope that helps
but if thos pics are not yours.....getting it started the first time can be really difficult, there is a ciclip in there to stop ths shaft coming out easily. lever it from multiple points between the slot on the driveshaft and the diff cover bolts with bid screwdriver / pry bar.
if you are that far out and stuck you must have it cocked at an anle somehow...straighten by tapping on the side of the driveshaft and it should pop right out.
unless you cant get it any further because the other end is stopping it....in which case doo doo covered it
You need to remove the outer end from the wheel hub first. That entails effectively disassembling the front suspension to get enough movement of the hub to slip off the end of the shaft.
Then use pry bars in the machine slot of the inner end to lever the shaft out of the diff. (no need to remove the diff cover plate).
BTW - that's the RHS shaft. It only appears to be the LH shaft because you are looking at it from the front.
guys,
having the same problem at the moment.
I have separated the shaft at the CV (grease everywhere), but cannot get the inboard part of the shaft out. Have undid the diff cover (only gotten it out about 15mm) hoping that once it is out of the way I might be able to get something behind the shaft end.
Can anyone help with exploded views / diagrams.
Ok well im preparing to pull the front passenger shaft on my RS4 Stagea as I've got a split inner CV boot :)
Theirs a good outline on page 10 and 11 of this manual for doing in for a gtr so think it should be much the same.
http://www.scribd.com/doc/4964854/GTR-Engine-Removal
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
