Anybody used Penrite SIN 75 (75x90) gearbox oil or have any comments on it ? There is also SIN 80 (80x140) which may ? be a goer for summer--or not ?
I'm thinking of using it in my R34GTT as I used Penrite 10/10 SIN in a WRX gearbox a fair while ago and it worked well but for a Skyline well , I know nothing :P
https://www.sau.com.au/forums/topic/290069-penrite-sin-75-sin-80/
i put sin 75 in mine the viscosity u list isnt wat the bottle has on it it said 75-85.... had it in for 5000k's on a freshly rebuilt and cryod box and afta doing sum near on 250km an hr runs the box has developed a mad whine.... admitly the car has 402rwkw atm but still. not blaming the oil could just be a part failure. but just letting u know. sound only developed afta extended periods at very high speeds
Thanks mate, I think you might find that the 75-85 is a synthetic blend, the labeling is a bit deceptive. The sin 75 is a fully synthetic product and carries 75-90 printed in smallish letters on the lower left side front here's a link http://www.penriteoil.com.au/products/gear...sin_gear_oil_75 the SIN 75 is about $55.95 for a 2.5lt bottle the 75-85 blend is around $28-32 for 2.5ltr, I think , I know I nearly bought the 75-85 just on bucks but decided to bite the bullet as I'd only change the gearbox oil evry 12-15 months as I do bugger all klms.
I changed all my oils today, motor/gearbox/diff and I used the penrite SIN 75 in the gearbox so I'll post if it goes crook. I've got a 98 R34GTT with 80000ks on it which I think are genuine.
I've got a fat exhaust but wont be going beyond a Nistune motherboard and tune when it comes to more mods so it won't be working that hard.
:cool: Farkin bad news on the box, what gearset are you using with that much kws ?
Fully synthetic in a gearbox should be good for 300,000+kms. So no need to ever change it again!
sin 75 and sin 80 are hypoid diff oils. not sutible for your gearbox. penrite manual gear 70 is the corect oil.
;) Hmm, not acording to Penrite when I phoned them, unless of course I misunderstood which is not beyond the realms of possibility given that I'm an ole fart. :)
Not doubting you on this but the oil that came out was a deal heavier than 70 grade and its a 5 speed box.
Penrite sez:-
SIN GEAR OIL 75
Synthetic gear oils engineered for maximum protection, life and performance. Use for transmissions and differentials for all types of high performance cars. SIN Gear Oil 75 has been specifically enhanced to survive the extremes of V8 operations.
Exceed API GL-5 and GL-6.
Package and Code:
2.5LSING750025 20LSING75020
AND
MANUAL GEAR OIL 70
A great synthetic performance gear oil featuring new generation technology. Suitable for many modern 6 speed manual gearboxes where originally a synthetic or mineral automatic transmission fluid was specified. Ideal for T-56 manual transmissions and VW/Land Rover gear boxes.
SAE 70W-75, API GL-4 Plus, BOT338
Package and Code:
2.5L MGO70750025
20L MGO7075020
Edited by BASHO
My dumbass way of looking at these similar oils is;
GL-4 for is best suited to gearboxes
GL-5 for is best suited to diffs
and unless i have a good reason to do otherwise, I use the manufacturers recommended viscosity (so i probably wouldnt use 70W-75 in my gearbox)
:) Love the methodoligy.
I have absolutely no idea what the OE spec for the R34GTT gearbox is if you could post it up it would be of great help as after huge searching on here many others don't seem to know either.
After refering to this post http://www.skylinesaustralia.com/forums/Tr...ts-t205993.html I then phoned Penrite and asked them what thier equivalent to Syntrax 75-90 was as I had used Penrite 10/10 which they no longer make and was happy with it , thier advice was SIN 75.
Penrite also didn't have an oil spec'd specificly for an R34GTT manual gearbox as such.
i use penrite Sin Gear 75 in my silvia 5 speed, and my differential. but i have a vicous LSD... i'm not sure about skylines though. it's been in there since i had the car, gearbox still feels good, no crunching. LSD still hooks up pretty good.
OK , the SIN 75 feels way to heavy for the gearbox in my R34GTT the gearchange is sluggish and the selectors work way to hard going from the snick to a clurk noise when changing gear noise , I've hoyed it out and have gone with a straight Nulon 80 smooth shift on the basis that Castrol recomend VMX 80 or VMX 75/85 and I couldn't find any on the shelf on Sunday, this again is a Hypoid which is probably another wrong'n.
I'm going to phone Nissan and see if I can find out what wieght of oil they would put in if they were servicing it , which they won't.
:P wish me luck :(
Edited by BASHO
IIRC 32 GTR, 33 GTR, 33 GTST and 34 GTT gearboxes have pretty much the same internals, with some minor revisions along the way (ie extra syncros on third in series 3 33 GTR). The 32 GTR spec is 4.1 liters of 75W-90 GL-4.
:( Thanks for that, I actualy found out from Nulon that the spec is GL4 75w-90 , Nissan wouldn't tell me and had no oil to sell me iether, made me feel a bit like Oliver Twist. -More Mr Beadle please sir ?
A bit of perhaps useless infi on gaerbox oil specs according to Oil Mfrs for the R34GTT.
CASTROL--------VMX 80 OR VMX-M 75w-85
MOBILUBE-------XHP 75w-90
NULON----------75-85 full syntnetic SMOOTH SHIFT.
I'm now puzzled why my gearshifting was so heavy if I use 75w-90 was it because I used oil with Hypoids in it ? WTF are hypoids anyway, everyone I ask looks sheepish and changes the topic.
This is of course is intended in the style of Clarkson , Hypoid what is Hypoid is that an oily steroid ? etc
Does this help? hypoid lubricant for read (sic) differential?
Apparently hypoid oils are for hypoid gears ....
Thanks, helped mighty, bottom line is that synchromesh gears dont like Hypoid oil hence the syncro drag, for want of a better term, that I am experiancing though as I understand it hypoid oil would actualy be a stronger option wieght for wieght than non Hypoid , also interesting is the fact that GL4 is now considered obselete.
After running around all the local Autobarns, Suercheeps, Repco's etc I found that GL4 75w-90 non hypoid oil is rarer than rocking horse shit, in point of fact I found none.
This may explain why no oil manufacturer specifys 75w-90 , they just don't have it , so they spec 75w-85 or whatever they have thats sorta nearest--how encouraging :cool:
Except good ole Mobil who do 75w-90 GL4-------- in 20ltr drums , go to Kingdom OZ to actualy get even that, although I was told somewhere in Burliegh may have it.
I was offered Redline light at $160 3.85ltr bottle by Bursons but have been told that this has a habit of turning to cheese and requires a gearbox rebuild to actualy get the stuff out .
I now have even less of an idea what the best oil for this gearbox woud be than when I started.
  • 3 years later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
