Hey everyone, I posted here long ago but thought it was worth another try.
I've got a red R30 sitting here. Originally two tone silver/blue but has been repainted by me and a mate.
Car needs a new rhs brake light, rhs drivers side window, windscreen, wheel bearings and battery.
Apart from that, as far as I'm aware, shes mechanically sound.
Its never been registered in SA and has been at least 24 months from being registered at all.
To be driven in SA it would need to be taken through Regency,
now before you freak out. It just needs a security/ID check to make sure its not stolen, not one of those thorough checks.
I haven't driven her for quite a long time though so I'm not sure if anything else has developed. Shouldn't have though.
I was originally asking $1300 or something to not even cover the purchase and paintwork.
To be honest, i know it needs some work, but its still a good little car.
Asking $700 neg.
Any questions or requests for more pics, just ask.
https://www.sau.com.au/forums/topic/290088-r30-4-door-for-sale/
It's not necessarily a Ti, but being an RMR, I think they all had air-con & PS anyway...
(they certainly had 4-wheel discs)
I think power windows & mirrors would give more indication of the spec.
My 'plain' '82 aus-spec GT had PS & AC, A mate's '84 has AC, but no PS (it now has my old PS fitted)...
Asking $700 neg.
mmmmmmmmmmmmmmmmm!
$700.00? that's about what I would pay for it. You got a deal at this price, just let me know how we do the dollars.
Cheers, D
Just a quick note...
Started her up and took her for a quick spin around the block. Still runs strong!
Wheel bearings seem to have fixed themselves, lol. Well, at least, they're not making noises anymore anyway.
Another thing regrettably however... The indicators are a bit touchy. If you just click them on, they don't work, but if you hold the stick half way up/down then they work fine... Maybe just dodgy old wiring. Not sure.
Had the same problem, fixed by cleaning the switch contacts.
JH
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
