needs modification? or straight fit? with all the navi working fine?
will i be able to get maps put on this unit? or same story again with no car in australia with the australian maps that will load on this unit?
NO modifications needed, a few little mis fits, but otherwise OK
Make sue you get a full unit with a face cover from US!
The CD Changer slot is located slightly lower, along with buttons
Navi is working, everything runs, BUT I HAVE NO MAPS
same question..
i thought US goes by Miles not km's?
did you converit it over?
There's a choice in the menu to change from Miles to L/kms, which is great! :whistling:
My stagea was doing 8 l/100 on the highway for 100 kms! :D
that is friggen awesome!! very VERY nice work!!!
are you going to put up an FYI on how to do this? or perhaps sell your services to perform these conversions??
Its all quite simple to do yourself, just have to find removal guides for stereo and DVD unit, and follow the same to put it back in.
that makes your radio and PN2615 out of a 2004 model. they changes the mechs in them to avoid the issues with the 2001-2003 cars. the only realy way to sort it is to gt teh correct main panel.
I got caught on this a while back.
if we can get navi disc for this it'll be awsome
Also does it have DVD player now?
wat does the D/N button do now?
NO DVD player, NO TV unfortunately.......but like anyone is going to use it
D/N is day/night lighting
can't please every one eh?
this is the english work around you have been presented with and you still complain :)
if you guys with the NAVI versions want english buy the box and the buttons. that will sort it for you.
want it all to work buy the whole lot and swap it all out.
give the guy credit - he's taken the initiative to fix what he sees as a problem.
Quick questions for your Chris.
Would this setup work in an M35 RS?
I only ask as I have the single DIN Clarion unit with 3 gauge setup as opposed to the integrated unit.
Would everything hook up or would some re-wiring/splicing be in order?
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
