alright i just reasonly bought a 32 gtr..
well the problem with my car is smoke just keep coming out from the exhaust really bad every timee i step onto the pedals?? why that does it mean the turbo stuff how would i no this becos i am getting lagg from it aswell or is the engine stuff piston ring or some thing please help??
should i get a compression test done or gettting it tune will help?
https://www.sau.com.au/forums/topic/290578-i-got-a-blue-grey-smoke-guys/
It can be either the turbos or the motor.
If your lucky, the turbo(s) have done an oil seal and oil+exhaust heat like that of the turbo = blue smoke. U will have to get your turbo(s) rebuilt or purchase some other ones.
Otherwise it can be your rings and thats more costly.
A tune will not help the situation, blue smoke always = oil.
It would be wise to get it to a mechanic on a tilt tray or off boost if you are unsure, they would probably be able to diagnose the issue for you easily.
When you say lag, what are you comparing to? If you just bought the car how do you know if thats not how the car drives?
Why did you buy it if it was smoking? Didnt you notice the smoke wen test driving it? Or did this just very recently happen
l
my car gone worst!!
i just went for a drive an this is how it went to answer your qustion.../
when you said lag... its feel like the turbo doesnt want to spin an smoke are coming out like crzy is that the problem or the piston problem?
i couldnt get to third gear becos there was tooo much smoke coming out. answer bk please man i wana noe so i can fix it. thx man if u can help me fine out the problem ur a legend!
when i bought the car its didnt do this that why i bought it. it look healthy when i got it!!
so yeah man im not that stupid if it did looking like that. when you c this car you would get it aswel for good price!
Im not saying ur intellectually challenged bro,,but i think the problem may hav been there before u bought the car..hence the good price u must hav got it for
I think the seller saw you comin'
I think the seller could smell the cash
I think the seller has bolted
What city are you in? You'll need some expert help. Do you have any more moolah in the kitty for repairs?
im in victoria what about you?
I would definitely scan the Victoria Subforum for technicians who they recommend as being trustworthy to get your GT-R up to speed.
I wonder if there is more than one problem; and this worries me a bit.
Get back to us pls.
l
my car gone worst!!
well if it were me, id be taking off the dump pipe from the back of the turbos and checking if you still have all the fins on the turbos, I would also be taking off the intake pipes and checking the front of the turbos (where they suck in air) if its got lots of oil... if either of these things are true then its more then likely ur turbos. I would also do a compression test on the motor to be safe.... and if i didnt know how to do/check any of these things it would be straight to a reputable mechanic.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
