Personally, dont like the ad. It's gay.
Id've been happy if they didn't make an ad for the GT-R.
I remember Carlos Ghosn saying if the car appears on any magazines, on radio, on the tv, then the marketing of it will be a failure (documentary on the new GT-R, i think National Geographic?)
https://www.sau.com.au/forums/topic/290727-new-nissan-ad/#findComment-4863807
yeah nissan have some cheesy ad on tv... shows the 370z, murano, and GTR in the same ad..... "shift the way you move" or some crap. would be nice to see an ad just for the gtr on it's own. guess nissan have tightened their tv advertising budget..
https://www.sau.com.au/forums/topic/290727-new-nissan-ad/#findComment-4864658
yeh definetly... and the ppl with watery black smoke around them... wtf... does not sell it for me at all.... I mean theres so many good features about the GTR and you only get a gernal overview for 5 seconds.... whos going to buy it based on that.
https://www.sau.com.au/forums/topic/290727-new-nissan-ad/#findComment-4865978
there's probably not a lot of revenue generated from spending big $$$ on GTR advertising, where the price is out of reach for your average Joe. They are clever in that respect, nissan are a business afterall and probably make most of their money from the small/medium size car market.. so it makes sense that's where they focus their marketing dollars.
https://www.sau.com.au/forums/topic/290727-new-nissan-ad/#findComment-4866102
I actually don't mind that ad.
Ad's aren't always lathered in product info and demo's to sell the product. Most of the time (as is being seen as a common trend with Cadbury) the ad's are purely used to grab your attention.
I think if Nissan were to change anything in this ad, they should take the Murano out. It's got it's own line of ad's currently, and doesn't fit the theme of the ad (370Z and GTR being sports cars).
I'm not sure what sound they've got (as i don't have volume on my work cpu) but this may make all the difference as bad music will create a bad feeling around the ad from it's viewers.
Some people have mentioned that they wish the GTR had an ad on it's own. And yes that would be good. But it would be a waste of money for Nissan. The GTR is not one of their mainstream cars, and as GTTR34 said, it's out of the price ranges of most average joes. So for most people (excluding GTR fans) they would probably take little to no interest and change channels. And depending on the ad they created, it may very well "cheapen" the image of the GTR.
It's exactly the same reason why Ferrari doesn't advertise.
9/10 people can't afford a Ferrari.
Putting a Ferrari ad on prime time television could possibly "cheapen" its image if it's surrounded by cadbury and kitchen cleaner ads, and would be seen as "common"
Ferrari's brand sells the product, not advertising. Maybe this is what Nissan is trying to achieve. Their maybe hoping the GTR doesn't need advertising, just a little mention in an ad?
https://www.sau.com.au/forums/topic/290727-new-nissan-ad/#findComment-4866124
You hit the nail on the head. Thats exactly what they said in the making of the GT-R documentary on Discovery Channel a couple of years ago. There advertising was focusing on creating a hype through it featuring in video games and the like, they wanted to make people want to see it, find out more about it and dream of owning it.
https://www.sau.com.au/forums/topic/290727-new-nissan-ad/#findComment-4867271
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
