motorsport connections in seven hills have them (just behind hungrys on abbot rd). no doubt there are cheaper locations
Really appreciate it. I will have to pay whatever they ask because so far I have had no luck anywhere else. Its not far from my house anyway. Cheers.
Turns out there is no need for T-peices. I have my oil filter relocated to the front of the car and the bracket it sits on had two bolts. The bolts didn't seem to be doing anything so for interests sake i undid them only to have some oil come out and the thread size to be exactly the size I needed for my senders. Lucky indeed.
Thats what they are there for. An oil filter spacer plate usually has two holes threaded for oil temp and oil pressure.
Put your oil temp in the bottom hole, oil pressure usually uses the top hole because you get more clearance around it, the sender is largish.
Right on the money there! Fits perfectly. Cheers.
