Mardel and me in the 5 car drift train.. that shitt was nuts
http://vimeo.com/14502662
4 car drift train...neeearly hit Greenie
http://vimeo.com/14502499
Driving with dec's in his daily
http://vimeo.com/14502392
Evan in the red KE and me, was awesome to drive with him and my old car haha
http://vimeo.com/14502202
3 different runs
http://vimeo.com/14512327
Edited by Simon-R32
hey mate
the arms are looking good. what brand of coilovers are you going to?
have you mainly gone down the custom arm route to get rid of your binding issues?
got some BC ER's going in.. should have em today.
binding, correcting of roll centre, also suspension bush binding elimination are the 3 big reasons
BC ER's i got... decent value!
so i dummy fitted all the gear tonight and i got two issues... one is i painted everything up and forgot to weld a lock stopper on the arm LOL so will need to work out a spot and then grind back paint and weld on a stopper.
2nd is my sway bar link... i dont know where i f**ked up but i did.. its on a bad angle and when i move arm towards pos castor it binds and hits. so will have to redo that too.
apart from that it looks like its gonna have MAJOR lock with xero bind.. arm is not straight with the tie rod by a long shot so will be awesome.. took some pics and theres no castor rod fitted as im still waiting on it to be machined.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
