hmmm must be something wrong with mine! ehhehe , what clutch are you using and how much does your rev's rev out to?
My motor is a un-opened rb25det doing 250kws on 17psi with a highflow turbo . Do you think if i tell my tuner to increase my revs long? would it effect my motor more?
PS - nice turbo !
Edited by geraus
PS - nice turbo !
a few things to note. simon runs a r34 neo rb25. they are a far more advanced engine than the r33 rb25.
simons car has nearly 400rwkw not 250 but there is a fair bit of sicence behind a decent turbo and the flow caracheristics of a turbo and would say that even if you squized more power out of the turbo you have it still wont give you the same results as a gt series garrett.
also its not the power as that is just a peak measurment. its all the area under the power curve that counts.
it can also be alignment settings, tyre type and Key note tyre pressures that make tyres grip different.
1/4 past f**k all difference between a R33 RB25 and NEO in real life performace when they are tuned to this kind of power...
GT Garrett's are also not the be all and end all of turbos, my cheapy Kinugawa turbo does the job just as well as a 3076R :)
I think you will find that the difference would be outright power (as you have suggested 400rwkw is not 250rwkw) and also weight will have a huge factor. A stripped S14 compared to a street R33 would be about 400kg difference at a guess and that is MASSIVE :cheers:
Edited by SimonR32
I've had quite a few tuners tell me that there is quite a difference and that it is basically the same as an rb26 head. You sure there isn't some truth in this?
I have also been told they respond a lot better to modifications that the old RB25 due to the head setup etc... I think the rods are stronger too? But as i have an R34 i have a NEO if i like it or not :banana:
As for the high flow setup, i decided to ditch my high flow as it was laggy and overall not that impressive... I am looking forward to the 3037 conversion for the response and power...
REALLY looking forward to the back to back test on the GTX vs the GT!!!
No doubt they are a better design than a R33 RB25 head. They have solid lifters and better cams etc
What I said was the differences do not make a huge difference in terms of relative performance at this kind of power level!
That was sort of what I was getting at, how much of a difference of peak power do the different heads produce in certain power ranges?
<br>hmmm must be something wrong with mine! ehhehe , what clutch are you using and how much does your rev's rev out to?<br><br>My motor is a un-opened rb25det doing 250kws on 17psi with a highflow turbo . Do you think if i tell my tuner to increase my revs long? would it effect my motor more?<br><br><br>PS - nice turbo !<br>
<br><br>Just hope on e85 itll pump you close to 300 and pump the torque up aswell ever since I went on the stuff and at the last drift day third goes no worries and alot safer.
i did wonder if id get some resistance to my comments. whist yes at the same power lever there is f all difference but the fact they have solid lifters and better designe through out makes them a different motor.
i am also yet to see a good example of a stock r33 rb20 making 400rwkw. the few examples i know of have only been made with massive turbos with bad responce.
i also know that a garrett is far from the best but the actual flow differences between a hiflow and a gt series is light years in my opinion. ive had real life experiances with both.
What about my R33 RB25 (with a dead stock motor, stock cams etc)???
Edited by SimonR32
comp test isnt 100% accurate and i did also say i used the workshop comp tester which has been known to read lower. either way.. it goes hard. i have no issues with the motor so far. BTW what are the CP's you have for sale for the neo?
as for neo/non neo differences.. as simonr32 said theres not much in it when you start running large boost with a decent turbo capeable of flowing it. both will do the job. the neo's are just a little bit better with their solid lifters and GTR rods.
Geraus: the reason yours doesnt make the post is because of the turbo.. a highflow is a basic upgrade and perfect for the street. but no good for anything over 280 ish rwkw. anything more then that is GT30 territory.
at lower boost around 16-18 with lower power levels around 250ish do you think there would be much difference then?
not heaps... from all the work ive done on neo's and non neo's... the neo's prove to have more punch in the midrange.
EG: a neo with a HKS GTRS vrs a non neo with same turbo kit.. the neo has a bit more torque and earlier on in the midrange then the non neo. i would assume this is the flow charactoristics of the head
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
