Since you've done so much damage, why don't you just get another neo from a wrecker and go again. It only died because your oil was on the track. I think a neo with a good sump will last for ages. 90% of rb's die from oil starvation of some description, or a bad tune. Don't see too many die from being pushed too far
i would but i cant find any around for a reasonable price... im not paying 2.5-3K for just a motor like some wreckers want,
mercuary motorsport proved you can push 700 hp from a stock neo and then subject it to drag racing for a while with their VC commo they built for a customer.. i dare say the rods and pistions are strong things!
i shall start a slow build of another block i have on the side... will get it ready for next year
Yeah the things that kill RBs are almost always oil related, fix that and you'll have a very reliable motor, nissan knew how to build them better than a lot of builders out there. I'd trust some guy that built 20 motor a day for years over some muppet that takes your $10k of parts and gets the clearances wrong.
i would have found a way to make it work lol.
well good news anyway i got my new crank tested, fitted with crank collar, ACL race mains and big end bearings supplied, and maching of crank for 400... not a bad price! just need to re-assy. check tolerances and then put it back together
Who is doing the engine work for you champ?
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
