shakedown today at mallala... first time out and i had all sorts of cutting out issues... would just cut out big time in the midrange when on the throttle.. was hell weird. it wasnt until Decs from Garage 7 came along for a passenger ride and said its boost cutting. the target boost is set to 18 psi with a cut out at 22 psi to protect the engine from overboost (plus the map sensor only reads to 22psi so cant set higher) for some reason on the dyno it never spiked but on the track with some hard throttle mashing it spiked to 22psi and cut. so we backed the target boost back a few psi and problem solved.. now peaks at 18psi and doesnt overboost.
once that was sorted have it some hard laps and was pretty happy with the overall performance.. its a little bit lazier coming onto boost but once it is it just pulls hard. didnt bother going for lap times as i was running shit tyres and drift set up. was all over the shop with shitty half worn sunnys on the back lol.
Good to meet you mate sorry I didn't get to take you for laps. Had issues then Decs from garage 7 rocked up and got stuck into data logging it. Found boost was spiking and cutting rpm.
that's cool Simon there's always next time, car sounds great with new setup!!! All the best for Tassie :thumbsup:
Quick question with the dyno graph simon, with the rb25 head and stock cam you made same power on 98 and more torque than you are now with 26 head and running E85. I know your making less torque because of the manifold but I thought you should have see a max kw jump from the e85 and 26 head.
nah what happened was when we first tuned it with BP98 and stock cams it was tuned on the dyno with no temp correction turned on. cause there was no temp probe so the dyno software automatically assumes 100 degrees ambient air temps. hence the inflated power and torque figures.
it means that the very first tune that we did on the first set up was out of wack yes... then the owner of the dyno (not my tuner, different person) purchased a temp sensor for the dyno so we were able to tune correctly from then on.
anyway.. bottom line is, yes its down on power but once cams and cam gears are installed it should bump it back up
wow what an insane read from 1 to 41 tonight, awesome build man, im also in the process of building my 32, will hopefully be going too the same depth of mods as you on mine, might see you on the track!!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
