I'm really digging the radiator set up... hope it works well for you.
Most people can't appreciate the time and skill it takes to produce neat wiring solutions. Just make sure you are using the correct style of deutsch plug crimps for the pins and sockets.
It's comming along gear guns.
PS... I had my first proper day out sliding (Baskervill) last weekend.. was a blast! I can see how it becomes a destructive addiction.
That's beautiful... Your wiring is just outstanding, really makes me want to strip my car and do everything custom. Because having your indicators on a switch panel in a street car is completely necessary :P
Seriously though, I'm loving this build. I just tend to just sit on the side lines and applaud quietly.
got less then a week to finish this thing for Round 1 ADGP and its going to be an untested car/set up :( oh well see how it goes.
anyway heres todays efforts... im wrecked. ive spent all my time either at work or working on the car, sleep is rare.
mock up of fuse/relay panel.. then a power up to test all circuits.. passed with flying colours!
made up swirl/fill pot for the rad, this is the highest point in cooling system,
sealed off the floor holes
epic switch panel! LEDs are green and have bright/dim circuit, interior light, etc heaps of neat touches
Nice work, I love it!
.... just one thing... you might need to re-orientate the ewp. the way you have it, there will be an air pocket trapped on the back of the impeller, causing it to cavitation and create more air bubbles.
today we had the rad back out cause we found a leak in one of the end tanks. put it all back in and then bled it up. we vacuum filled it and that worked mint. in total it took an hour to fill and bleed and took 20L of coolant. we ran the EWP constantly while it was full and kept adding water in the funnel until no more air bubbles came out. EWP works mint and no cavitation was heard at all. the EWP is mounted lower then the bleed point.
fuel system all done. hard lines from boot to fire wall with bulkhead fittings then braided line in engine bay to connect it all. clean. effective and out of harms way. nothing at all to get damaged on ripple strips etc.
just means the cabin is getting awfully full haha
the red things are buttons to scroll through the dash since there are 4 pages. you can also use them to change brightness of dash and various other simple functions.
the leb spec shift light can be set up to come up for any warning light. EG oil press, too hot etc.
got it running last night... after a massive fuel leak. turns out the tank had a hole in it. So swapped a tank out of a 33 4 door and bolted that in... no 5 min job but had to be done. then we put fuel back in it and started the steps to get it running. lots of setting up and calibrating of sensors etc. then it fired straight up and settled into a dead smooth idle.
warmed it up to 80 degrees using the pump on 30% flow, then we turned the fan on 100% and it dropped down to 55 degrees lol.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
