Hey people with aftermarket wheels what offset wheels do you have? +25,+0+17 etc
Im thinking ill put on +17 wheels has anyone got pics of a car with +17 offset wheels on it? I just want to know if they will sit just inside or level with the guard?
Also with lowering does anyone make superlows for r30s? rang burson and king can only do low. I want lower than that..
Cheers
Marc
https://www.sau.com.au/forums/topic/291109-offset-and-lowering/
  MAG86 said:
Kings make lows, and any lower than that is just asking for trouble...
get custom coilovers made so you can atleast have height adjustment
the super lows would be a stop gap only, ill try to get another
Set of S13 coilovers for this car as iv done with my car in NZ its far cheaper than making them
Also low springs are not low enough!! Lol sorry but you guys don’t lower your cars
here enough! I want it sitting NZ low or Japan
low like this (im aware it will need a sump gaurd)
And that brings me to wheel offset will +17 offset wheels be ok? this is the most important question
  FJ20DR30 said:
Your a ledgend mate yeah they should be just fine the wheels iv got ar 17x8 +15(sorry) so they should look almost the same as yours do im guessing i dont really know on offsets how exactly they work
The outside of your wheels will sit 12 to 13mm further in than those shown in the pic.
Hey HR31_RB20DET
Seen your car on R31 forums and think it's one of the nicest I've seen.
Are those wheels Rota RB's in 17" ?
Where did you buy them as they'd look great on my DR30.
Weird ?
how can that be if the standard offset is +25? standard wheels dont sit 21 mm closer than those r31 wheels do, do they?
well i can space them if i have to or want a wider look
Hey HR31_RB20DET
Thanks, yeah they are the Rota RB's. I bought them in a group buy off the 31 forum, not sure if the group buy is still an on going thing. Maybe try sending Fatz a PM as he gets them through Otomoto at a cheaper price.
Link to the original group buy: Rota Group Buy
You may want to study how wheel offsets work otherwise it could be hit and miss. There good info out there... even calculators to make the process a little easier.
An 8 wide and 8.5 wide wheel will sit at different distances even if the offset is the same.
  FJ20DR30 said:
Weird ?
your wheels are +15 while the ones in the pic are +4.
This mearns they will sit 11 mm inwards,then your wheels are 12.7mm narrower that the RB's so the outside edge of your wheels will sit in half of that equaling total 17mm further in (sorry my maths were off a little this morning)
I did a quick search, and found this one, it has pictures that move with the changes, it may make it easier to see what you want.
http://www.morfed.net/wheel-offset-calculator/
http://www.rims-n-tires.com/rt_specs.jsp <---This one looks good.
this may also be useful, if you wanting to change rim sizes, but keep the same speedo reading
http://www.miata.net/garage/tirecalc.html
Nigel
Edited by noddle
huh? im talking about the cars factory wheels being + 25 offset, compared to the +4 offsets.
thus meaning the factory wheels are 21mm inside! plus the factory wheels will only be 6"ish wide so there for being close to 4cm inside what those plus 4 offsets are! thats just alot! i cant seeing there be that sort of difference, and those +4 wheels still sit inside the gaurds its not like they look wide they just look normal with a nice dish.
does that make sense?
Actually the front rims sit outside of the guard slightly, If I had no camber front and rear they would hit the guards, fronts running around 1.5 degrees camber and the rear has 3 degrees.
Pic without tyres fitted.
A comparison pic, same height and camber with 17x7 +20 all round,
Good info !
I wouldn't even bother with any of the Aus/NZ brands like Cobra or King, Japan is the best place to go if you want lowering springs for a DR that are to your tastes... but be warned you may end up shortening your shocks in the process.
as for offset I run 15x7 +15 on the rear and 15x6.5 +20 up front, however due to the style of rim (reverse mesh) I've had to space the fronts by 5mm to clear the brakes. Tyres are also a bit on the 'balloon' side being 215/60 rear and 205/60 front.
here's mine on its "low" Japanese springs, I could have gone lower but why sacrifice ride comfort and bash the sump every time you go out for a drive?
Cool cheers
how ever ill upgrade the car to coil overs (s13 for the ride height in the time being ill cut them if they are progresive its no loss, also im getting a set of these what do you guys think?
anyway they are good offset and i can get them new for cheap
    • Nice one, I'd argue that the white S1 RS260 is certainly the best looking of the Stageas. And yes, fully agree on the forum situation. It's a bit of a shame, but at least SAU is a good place to be. I found the facebook groups to give me FOMO because people were trying to one-up each other and show off in some way. Feels much more natural here. There are people with seriously nice builds, but I can appreciate it rather than it making me question my life choices. Might be that people are more open with sharing how much work/money/suffering it takes to actually get there.
    • Evening, wanted to pop in and finally register to say hi to everyone here on SAU!   It's been a while since I've been active on a forum, but back in the day I used to be relatively active on ClubLexus and other hobby-related forums. I'm glad to see SAU is still around, since with the advent of Facebook and Discord it seems forums aren't what they once were. As a recent new owner of an S1 260RS Stagea, I've found so many older guides and helpful tips from SAU that I figured I needed to join and say a grave thank you. My recent acquisition has only become legal in the US for the past year, and knowing that similar car enthusiasts from across the pond have already figured out the kinks and tricks to get these 25+ year old cars running well. I look forward to diving into more of the SAU forums as well as hopefully contribute some info myself for future posterity.   As a pic tax, here is one of the few good photos I have of my Stagea. I hope to get way more in the future!
    • Is this where I say "Hey man my airbox cost me horsepower in my Naturally Aspirated Engine"? (I know you need them for legality in NSW)
    • 1.5mm alloy folded up, it will need a tweek, as the angled bend only got to around 45° as that was the max that the break press would get with the other bends, and I needed a fair bit more, but and the alloy is easy to bend too my will by hand once I trim the lower section out I'll Dremel out and form the angle and mounting point on the lower section when time permits  As for the lid, I'm looking at going a "cap", instead of a flat lid to hide the fixtures a bit
