Hey people with aftermarket wheels what offset wheels do you have? +25,+0+17 etc
Im thinking ill put on +17 wheels has anyone got pics of a car with +17 offset wheels on it? I just want to know if they will sit just inside or level with the guard?
Also with lowering does anyone make superlows for r30s? rang burson and king can only do low. I want lower than that..
Cheers
Marc
https://www.sau.com.au/forums/topic/291109-offset-and-lowering/
Kings make lows, and any lower than that is just asking for trouble...
get custom coilovers made so you can atleast have height adjustment
the super lows would be a stop gap only, ill try to get another
Set of S13 coilovers for this car as iv done with my car in NZ its far cheaper than making them
Also low springs are not low enough!! Lol sorry but you guys don’t lower your cars
here enough! I want it sitting NZ low or Japan
low like this (im aware it will need a sump gaurd)
And that brings me to wheel offset will +17 offset wheels be ok? this is the most important question
Your a ledgend mate yeah they should be just fine the wheels iv got ar 17x8 +15(sorry) so they should look almost the same as yours do im guessing i dont really know on offsets how exactly they work
The outside of your wheels will sit 12 to 13mm further in than those shown in the pic.
Hey HR31_RB20DET
Seen your car on R31 forums and think it's one of the nicest I've seen.
Are those wheels Rota RB's in 17" ?
Where did you buy them as they'd look great on my DR30.
Weird ?
how can that be if the standard offset is +25? standard wheels dont sit 21 mm closer than those r31 wheels do, do they?
well i can space them if i have to or want a wider look
Hey HR31_RB20DET
Thanks, yeah they are the Rota RB's. I bought them in a group buy off the 31 forum, not sure if the group buy is still an on going thing. Maybe try sending Fatz a PM as he gets them through Otomoto at a cheaper price.
Link to the original group buy: Rota Group Buy
You may want to study how wheel offsets work otherwise it could be hit and miss. There good info out there... even calculators to make the process a little easier.
An 8 wide and 8.5 wide wheel will sit at different distances even if the offset is the same.
Weird ?
your wheels are +15 while the ones in the pic are +4.
This mearns they will sit 11 mm inwards,then your wheels are 12.7mm narrower that the RB's so the outside edge of your wheels will sit in half of that equaling total 17mm further in (sorry my maths were off a little this morning)
I did a quick search, and found this one, it has pictures that move with the changes, it may make it easier to see what you want.
http://www.morfed.net/wheel-offset-calculator/
http://www.rims-n-tires.com/rt_specs.jsp <---This one looks good.
this may also be useful, if you wanting to change rim sizes, but keep the same speedo reading
http://www.miata.net/garage/tirecalc.html
Nigel
Edited by noddle
huh? im talking about the cars factory wheels being + 25 offset, compared to the +4 offsets.
thus meaning the factory wheels are 21mm inside! plus the factory wheels will only be 6"ish wide so there for being close to 4cm inside what those plus 4 offsets are! thats just alot! i cant seeing there be that sort of difference, and those +4 wheels still sit inside the gaurds its not like they look wide they just look normal with a nice dish.
does that make sense?
Actually the front rims sit outside of the guard slightly, If I had no camber front and rear they would hit the guards, fronts running around 1.5 degrees camber and the rear has 3 degrees.
Pic without tyres fitted.
A comparison pic, same height and camber with 17x7 +20 all round,
Good info !
I wouldn't even bother with any of the Aus/NZ brands like Cobra or King, Japan is the best place to go if you want lowering springs for a DR that are to your tastes... but be warned you may end up shortening your shocks in the process.
as for offset I run 15x7 +15 on the rear and 15x6.5 +20 up front, however due to the style of rim (reverse mesh) I've had to space the fronts by 5mm to clear the brakes. Tyres are also a bit on the 'balloon' side being 215/60 rear and 205/60 front.
here's mine on its "low" Japanese springs, I could have gone lower but why sacrifice ride comfort and bash the sump every time you go out for a drive?
Cool cheers
how ever ill upgrade the car to coil overs (s13 for the ride height in the time being ill cut them if they are progresive its no loss, also im getting a set of these what do you guys think?
anyway they are good offset and i can get them new for cheap
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
