Rb25 Custom Inlet Manifold, 4x Mt/bf Drag Radials On Rims, Blitz Dsbc Sr Boost Contoller, R32 Tomei Headlight Intake
Selling the remaining parts from my project 32
Custom inlet manifold for RB25, modified std runners - old Subzero type one, with 70mm? 5ltr holden throttle body
Includes alloy fuel rail with 75lb ~800cc Holley injectors
Sard pressure reg
Injectors, reg and fuel rail were new, mainfold SH but polished up
$1000
Blitz Duel SBC spec R boost contoller, fitted but as new, includes all wiring etc, $400
Tomei R32 headlight replacent intake, painted black, as new, $250
2 x MT Drag radials, 255/50R16, 80% tread remaining mounted on polished 5 spoke wheels (std toyota of some sort) 16x7.5 + 50?, perfect offset for my 32 with +1 camber for the drags, with wheel nuts to suit wheels, $400
2 x BF goodrich draf radials, 255/50R16, 80% tread remaining mounted on polished 5 spoke wheels (std toyota of some sort) 16x7.5 + 50?, perfect offset for my 32 with +1 camber for the drags, with wheel nuts to suit wheels, $400
Parts in Adelaide but can arrange shipping of all items, emails [email protected]
Will get some pics of headlight and other stuff later today hopefully, cheers
pics of head light intake? very keen
Will find out for you, can you please pm me address or at least post code, thanks
keen on the rims and tyres mate how much would it cost to freight to gold coast?
cheers
Pics of intake and the 2 MT drag radials, the wheels and the condition of the BF ones are the same, just need to dig them out to get some pics
To clarify, Spec R? Wouldnt happen to be an Spec R ID?
G'day Mate, would you mind doing me a favour... when the tyres are lying on the ground, how many mm's to the mounting hub face (lying facedown and backdown).
I know you've given the offsets and tyre width etc, but it's going to be really tight on my car, so I'd like some exact figures if possible :whistling:
Thanks again,
Tim
Roy, no its the one in the lower pic, the std Spec R i think
I know you've given the offsets and tyre width etc, but it's going to be really tight on my car, so I'd like some exact figures if possible ;)
Thanks again,
Tim
With wheel/tyre flat on ground,
overall height of tyre at the biggest boldge = 260 mm
ground to wheel mount flat = 180mm
this would make sence, as the wheels are marked +50, half distance is 130 + 50 = 130
They fitted nice on my 32 gtst with camber set as it was, also had adjustable rear camber arms. Not sure if at one point I had to use 5mm spacers to get them to clear with different camber/control arms. But the tyres are worth it by themself so the wheels are just a bonus. Hope this helps
Would this be the right one for an R34GTT or would it be the spec S silly question maybe but I just don't know. :down:
The boost controller will work with any turbo, the spec S uses a different boost control solenoid, the spec R one has a better solenoid to contol the boost, hope this helps, cheers
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
