  • Replies 50
Well the engine builders don't think it's the sleeves as they don't protrude, and a new head gasket went in 2 days ago. Head was also just faced up when I removed it to fix a minor oil leak. It's very odd... and super frustrating.
This is the third headgasket to go into it now (original, second as a precaution after one of the valves was found to be 3mm longer than the rest and head removed, then this one a few days ago), head has been off twice, and entire engine out twice. A buggered oil pump: fixed... then a longer valve: fixed... minor oil leak from head: fixed... then what we thought was a leaking headgasket: fixed... and now milky oil :(
Just had it tuned at 285rwkw's @ 20psi and didn't even get to use it!
Where is your car these days Matt?
Dane, every time i start thinking engine rebuild for more power stories like yours scare me and i will stick with my 240rwkws odd
Crate engines mate.... Crane engines...
Nice power figure! Sounds like a weapon.. what's it weigh now?? If it's around 1200kg it would be super fast! Do you have a dyno graph to share... I'm interested in SR20 power curves..
I wouldn't know Matt, I haven't driven it!
I'd say it weighs in around the 1100-1150kg mark with everything taken out, but the cage added in. But I'll get it weighed soon enough once it's working. It felt pretty quick on the 250 or so rwkw's I ran ever so briefly at Sandown so 285 sounds promising.
Graph attached mate. It lost some power through the mid range with the cam timing change from it's initial Winton-last-minute tune, but gained a heap up top. Boost response is identical to what it was with 240rwkw's, and on the same boost level it makes a 45rwkw gain. It's also running 11.4 AFR's as we had a boost leak at the injectors so were running on the safe side in case they decided to seal up while I was running, so there should be a bit more in it at the same boost level.
Troy: Stay with the 240 mate. This was not worth the expense and hassles, despite the nice figure. I'm sure it will be great when it's all sorted but I could have been racing this whole time and that I won't get back.
But as Russ said, if I were to do it again I'd buy a crate engine.
285
Pre-Winton last minute tune
2lt tune, same turbo setup
Shall do mate. I'm heading there tomorrow so I'll ask him then.
I'd say yours makes more power across a broader range at the moment. I think once the boost leak is sorted it will improve a lot though but we'll see.
lol ya. came into the left hander, the pfc hand controller cut out. was like WTF! so wasnt concentrating and go into
the marbles i think. then went into the right hander and the back went on me.
skip into 3:00
Which straight is that? The one in front of the canteen?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
