  • Replies 50
plan for the worst.
turbos, and crank and oil pump. and if you dont need them then thats cash in your pocket.
Turbos have been rebuilt 2000 clicks ago by garret. brand new N1 oil pump has also only done 2000 clicks also. I will get them inspected regardless though, still gotta grab some cash etc.
i would suggest repairing the crank/new bearings
new decent oil pump (jun, nitto, greddy, tomei etc etc)
valve guides
sump extension/baffle (greddy the best bang for buck)
full nissan gasket set
and new rings
if you have more money chuck in a set of decent pistons and either arp rod bolts or a set of spool rods
and if you want to spend even more it will snowball and you will be up for around $20k
as dirt garage said you could quite easily use your stock rods for the build as they have been proven to hold the power. but if you have to buy a few new ones it'll work out cheaper going spool rods.
second set of rods = $200
resizing them $120
ARP rod bolts $120
the look on someones face when you make 467AWKW and run countless low 10's with them....priceless
i honestly doubt spool chinese rods would be stronger than stockers.
Edited by DiRTgarage
I'd take you up on that bet. $5 says they are stronger tuan the stickies.
Captain Metalurgy agrees with me too.
People just underestimate the stockies, that's all.
I will be taking dirtgarages advice for the rebuild, he is very confident in what he says and he has the cars to back it up. Just have to sort some things out first before I can proceed. Although I must admit my faith in the stock motor is wavering after my experiences. I am hoping it is human error and not engineering.
its unfortuately the fact you have no idea of the life the new engine had before you recieved it that has to be considered.
metalurgy yes...but have you taken into account the cross section of each item.
Id say we may be getting $2.50 each.
Sounds like a round at the pub to me
Either way, I've got a set of Spool rods you are welcome to dispose of for the test.
Have you got any standard rods you can part with? Would only need two
wtf? double post?
$100 tells me i can hear Noel telling you to get off the net and get your ass back in the engine room assembling 3 x RB26's.
I win!
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
