  • Replies 14.2k
laptop doesnt have one
that could be the problem!
usually laptops have numerical keypad functionality when you hold down the 'fn' key and hit certain letters like U,I,O,P,J,K,L,M.
try 'fn' and enter
Mitch are the chassis rails underneath the car bent? Is the roof creased? May cost more repairing then it would be selling in the long run.
not sure about the chassis rails , dont really care though
roof isnt creased at all
just want a cheap repair as its now my skid car so dont need some fancy repair work with a good paint job , ill repaint it myself
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
