  • Replies 14.2k
yer going really well, he is very demanding with food, and has already hit the 5kg mark, not even 4 weeks old yet.
besides lack of sleep, we are loving it.
how is sienna? how old now?
ahh these are great days Craig.....only prob is, they go way too quick and before you know it they've grown up.
Another 4 weeks and you'll be getting more sleep so hang in there bud.
Make sure you're getting lots of video of all the different stages as baby grows......we thought we were over doing the video thingy with the kids but now we look back on it and are glad we did.
You dont need a different tune etc etc like with e85 to run this 100octane stuff? I got 2 servos around the corner from me selling the stuffs!!
Btw; any of you guys heading out tonight - The weather is right on :D
ahh these are great days Craig.....only prob is, thay go way too quick and before you know it they've grown up.
Agreed!! Biggest regret so far is not having a video camera to film our daughter as she's been growing up...Will be getting one really soon though!!!
yeah never too late Shane.......even if you get a cheap Ebay job to get you going, do it straight away though. :D
I think you can go to the BP site and see locations for all their servos that have U98. Might try the mobile one as well.
It can be done as I know a few people that have done it in 300+rwkW GTRs.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
