  • Replies 14.2k
yer going really well, he is very demanding with food, and has already hit the 5kg mark, not even 4 weeks old yet.
besides lack of sleep, we are loving it.
how is sienna? how old now?
ahh these are great days Craig.....only prob is, they go way too quick and before you know it they've grown up.
Another 4 weeks and you'll be getting more sleep so hang in there bud.
Make sure you're getting lots of video of all the different stages as baby grows......we thought we were over doing the video thingy with the kids but now we look back on it and are glad we did.
You dont need a different tune etc etc like with e85 to run this 100octane stuff? I got 2 servos around the corner from me selling the stuffs!!
Btw; any of you guys heading out tonight - The weather is right on :D
ahh these are great days Craig.....only prob is, thay go way too quick and before you know it they've grown up.
Agreed!! Biggest regret so far is not having a video camera to film our daughter as she's been growing up...Will be getting one really soon though!!!
yeah never too late Shane.......even if you get a cheap Ebay job to get you going, do it straight away though. :D
I think you can go to the BP site and see locations for all their servos that have U98. Might try the mobile one as well.
It can be done as I know a few people that have done it in 300+rwkW GTRs.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
