I forgot that "hoons" were out today. Drove past AIR this afternoon.... The white smoke and crap blowing across Pt Wakefield road was disgusting. Its lucky that roadworks had the speed limit down to 60. Damn dangerous, so you "hoons" cant say that your're not causing problems out there, you are.
just one of the many gold comments taken from daves earlier link, see if you can spot mine :D
http://www.news.com.au/adelaidenow/comment...05-2682,00.html
  • Replies 14.2k
pretty cool huh, he is even fascinated by me oscar (fish), even tho the oscar looks like he wants to eat him haha
WTB RB25 + ecu, loom etc. will also post in wtb section
buy my rb25 and get free car $12500
heres an engine and turbo for you for $1150. It's a 4WD but i can confirm that the 2wd sump will fit, as i have a stag engine sitting in my garage at the moment.
http://cgi.ebay.com.au/Nissan-RB25DET-Turb...=item2ea85e0fc7
Edited by D_Stirls
more air talk.
believe it when i see it. love reading the comments, tyre smoke is toxic, kill hoons, think of the children, etc.
maybe a drag strip again one day but one thing is for sure, ANDRA won't have anything to do with the place while Jane is still breathing......and probably not in my lifetime either.
oh watch out
channel 7 news are doing one of those expose stories this week
guess what major issue they're tackling this time
no its not burnouts
no its not hoons either
its "uncovering HID headlights"
LOL
probably wont even happen in my lifetime.
the debate that mallala and the whyalla 1/8th mile strip is more than enough will probably still be going on. and mike ranns head will probably still be premier.
think i might just stay overseas. adelaide blows.
QFT
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
