  • Replies 14.2k
R32 GTS.T wheels go alright on a GT-R while I get mine repainted yeah? I'm 90% sure caliper clearance wont be an issue being that my car doesn't have the Brembo's
you may have to run slip on spacers on the front, because GTS-T rims on a GTS-T have about 4mm caliper clearance...
lil help, just took the gtr to work and was running fine.
till i tried to put my foot down just the slightest bit and i it didnt wanna boost, was nearly at work so i kept going and yeah it didnt wanna go above 3k. i had it in first has i pulled into the car park and was sitting around the 3k mark seeing if it would go over and it gave the loudest back fire ive heard outa that exhaust. im assuming the extra fuel i was dumping in built up. all the temps seemed fine. it also stalled while i was looking under the bonet after sitting at low rpm for a while.
almost seems like a intercooler hose has come off like once before, had a quick look when i come in but seems to be alright uptop, im going to head out there and jack it up at lunch and try n have a good look at those intercooler hoses.
is there anything else i should be checking? maybe split hoses or something.
damn cars
Edited by Inline 6
Ive got gts t rims on my gtr at the moment cause i had to go through regency and they fit fine no spacer required...
Cars off defect..... Not one issue.... :banana:
Weezy thanks for lending me that cat. i'll drop it back to ya probabbly sunday arvo/evening after i change everything back over
when you get the cat you bought of ebay installed right mikey ;)
Edited by Inline 6
damn cars
+1 for a cooler joins. Was it pufing abit of black smoke too?
No worries brother, just make sure you send me a text or something before you come over just so I can 100% make sure I am home. Congrats for getting off defect with little fuck around ;)
No worries brother, just make sure you send me a text or something before you come over just so I can 100% make sure I am home. Congrats for getting off defect with little fuck around :banana:
Yeah i'll text ya during the day once i have finished with the car.
Yeah the guy at the lonsdale depo was pretty cool was in and out in 20mins....
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
