ruby do u want dales seat? if not ill take it!
Yeah I do mate ... just a matter of meeting up with him. Gotta get the Stagea to the EHP show after work today, then a handful of appointments over the weekend to work around.
Why? You going to hold my welder to ransom? ;)
  • Replies 14.2k
The difference is going from the standard RB20/25 over the top intake manifold to a front facing manifold then there would be gains to be had, but Luke's manifold is a GTR manifold and there are plenty for GTR's making up to insane amounts of power still using the factory GTR manifold.
The Greddy and hypertune manifolds will give you slight increases in the top end when you are making massive amounts of power but you will be getting this gain at the cost of low down and midrange power, and like SLED said your only talking 20-30HP gains on a 700HP engine but your are losing like 80HP below 5000rpm
x2 :/
yeah i mean Turbotech :/
my current boost curve drops off a fair bit, from 10psi down to around 7 by redline. holding the boost higher through the revs with the new boost tee will obviously affect my tune wont it?
might do Damo - you had it all retuned very recently didnt you? give tuner a buzz for sure
The main reason I'm keeping the stock plenum is cause of it's legal and I'm short of the cash, also read they can hold over 400. Once I build the 30 with the race head i may go something more crazy
well i found out my exhaust manifold leak from the track day was due to only 1 bolt holding the turbo on!!!
coz the manifold doesnt have the locking tabs on it for the bolts they must have come loose.. LOL
but coz its a f**king ca its hard to get to the bolts!! ahhhh cut nuckles!
yeah i mean Turbotech :blush:
mines starting to spike out to 1.2 bar, but im thinking that has a lot to do with my hks inlet snorkel.
hey guys, first of all, farkinn brilliant weather eh?
perfect for my durable ranger skin!
need a favour, can any one pick up amy rb20 from ingle farm, and drop it off in ingle farm tomorrow arvo sometime?
will pay petty $$
hey guys, anyone who can help me with getting an apprenticeship as an electrician or at least point me in the right direction will be a big help
PM me your age, details and experience (if any) - can't promise anything but can at least give you some advice, Peer training is prob the way to go.
She looks nice any which way, but yes, preferably without clothes
She'd look better in my bedsheets!
:happy:
... actually, she'd look better with another woman on her ... preferrably Charlize Theron. :drool:
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
