  • Replies 14.2k
what you reckon he would want for a 3'' stainless pipe, from turbs to passenger door exit?
Call him and ask, he's doing the exact same for my mate Bengi on his turbo Starlet. Should look and sound sex
you where pushing alot more power than what matty will be thought chad...
but yeah, that did fail pretty bad haha
any clutch will do what chads did tho
it depends on how badly u punish it and how much power yr engine is putting out
on paper that clutch is supposed to easily handle chads power, so i have nfi whats going on there
im thinking of a nismo single plate clutch once i get my n1's installed, that with a nismo clutch cylinder too
-D
If you want spend the money and do it once Ben enquire about the Nismo copper mix multiplate clutches.
I know if I could fork out for one thats what I would buy. No rattle when disengaged, no heavy ass pedal etc, they're the way to go man. Pricey though
you reckon it would sound ok with a 20? might be a little too raspy... i dunno.
but would get mad rep points for teh flamage hehe
dont steal my idea craigy boy :D:down: btw u have pm on 31 club
I'd pay about $0
Did you see what happend to mine?
im not talkin bout buying one chad, im talkin bout the one i had in my 31. its still got half meat and all, would be good for someone with a streeter that wants a cheap clutch to start with. No good for me going to a 25 box and an aim of around 230-250rwkw
speaking of boxes, no conclusive searches have come up. ive been offered a GTR box minus the transfer case. Is this (beside the difference in ratios of course) essentially the same box as a 25 box?
Spot on, my mantra is always do it once, do it properly. Even if it takes longer to save up the cash, in the long run, it works out better IMO
I agree, which is why I was going to go with a Jim Berry.... and since its a daily, I'd be going with a single plate only if it was a nismo - nismo ones are apparently a lighter and stronger design than a JB so we'll just have to see... probably get luke to grab me one from japan when/if I need to replace the one I already got
When writeoff gets his gtr back, I'll see if I can drive it around the corner from his house - see what the clutching action is like, as I know he has a JB and is pretty happy with it - half the price too
Got a few months before it even becomes an issue (will do clutch when I change boxes)
-D
-D
I'll also have a race clutch in my car when (if) it ever gets finished =\
so u'll be more than welcome to give it a try at some point too
wogs + guns + hindley street = 2 people shot, one in the leg, one grazed in the arm
the fat wog said to the skinny wog 'oi u slept with my cousin bro' and the other one said 'nah i didnt for shit ay' and the fat wog went chk chk boom!!
-D
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
