  • Replies 14.2k
what you reckon he would want for a 3'' stainless pipe, from turbs to passenger door exit?
Call him and ask, he's doing the exact same for my mate Bengi on his turbo Starlet. Should look and sound sex
you where pushing alot more power than what matty will be thought chad...
but yeah, that did fail pretty bad haha
any clutch will do what chads did tho
it depends on how badly u punish it and how much power yr engine is putting out
on paper that clutch is supposed to easily handle chads power, so i have nfi whats going on there
im thinking of a nismo single plate clutch once i get my n1's installed, that with a nismo clutch cylinder too
-D
If you want spend the money and do it once Ben enquire about the Nismo copper mix multiplate clutches.
I know if I could fork out for one thats what I would buy. No rattle when disengaged, no heavy ass pedal etc, they're the way to go man. Pricey though
you reckon it would sound ok with a 20? might be a little too raspy... i dunno.
but would get mad rep points for teh flamage hehe
dont steal my idea craigy boy :D:down: btw u have pm on 31 club
I'd pay about $0
Did you see what happend to mine?
im not talkin bout buying one chad, im talkin bout the one i had in my 31. its still got half meat and all, would be good for someone with a streeter that wants a cheap clutch to start with. No good for me going to a 25 box and an aim of around 230-250rwkw
speaking of boxes, no conclusive searches have come up. ive been offered a GTR box minus the transfer case. Is this (beside the difference in ratios of course) essentially the same box as a 25 box?
Spot on, my mantra is always do it once, do it properly. Even if it takes longer to save up the cash, in the long run, it works out better IMO
I agree, which is why I was going to go with a Jim Berry.... and since its a daily, I'd be going with a single plate only if it was a nismo - nismo ones are apparently a lighter and stronger design than a JB so we'll just have to see... probably get luke to grab me one from japan when/if I need to replace the one I already got
When writeoff gets his gtr back, I'll see if I can drive it around the corner from his house - see what the clutching action is like, as I know he has a JB and is pretty happy with it - half the price too
Got a few months before it even becomes an issue (will do clutch when I change boxes)
-D
-D
I'll also have a race clutch in my car when (if) it ever gets finished =\
so u'll be more than welcome to give it a try at some point too
wogs + guns + hindley street = 2 people shot, one in the leg, one grazed in the arm
the fat wog said to the skinny wog 'oi u slept with my cousin bro' and the other one said 'nah i didnt for shit ay' and the fat wog went chk chk boom!!
-D
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
