Toyo R1R's... decent tyre?
Need new tyres all round and want some quality items. I know Kristian rated them pretty highly? Anyone else running them?
are R1R's the semi slicks?
I'm running T1R's (have been for 2.5 years) and theyre really good... only considering the goodyear eagle f1 asymmetric as wheels magazine rated it a tad higher than the toyos
-D
  • Replies 14.2k
I haven't used MSN in aaaaaaaaaaaaaages. Mainly communicate via sms or Facebook these days.
Same, less so Facebook (I always make myself look offline in the chat thing when I go on there so cunce don't start talkin shit :()
Supposed to be one of the closest things to an R-compound semi slick you can get in a road tyre. There was what you'd call a slight uproar about who should get access to them at what cost in drift comp circles as they were said to pretty much put anyone who wasn't using them at an unfair disadvantage.
Can't help you in any real world feedback but judging by what others have said it sounds like you'd be hard pressed to get a better performing tyre short of a semi slick, in the dry at least.
Edited by AndrewJZX100
Well by all reports they are up there. ID also recommend Kumho Ecsta KU36 and Maxxis i-Pro
any one know where i can get bolt on flares? or ant type of flare that i can graft on to my guards?
im having a vision of the 31 with them in black, getting drift teks soon and want to push them out.
hit AJPS up for some AE86 flares
same size of wheel arch to a 31
hit Decs up maybe and see if he's got some spares (Garage 7)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
