  • Replies 14.2k
Anyone who says that semi's are no good on the street really have no idea what there on about. Matt (Whatsisname) has them on his car and he cant believe how good they are either.
I'm thinking it's time for semi's on the street, t1r's are struggling, i'm guessing the ku36's are so cheap because there shit?
Ive looked up the thread on here about the special coating thats on them. Have use throttle body cleaner on them. The coating is still on there as i can see.
Cheers for the heads up tho.
No problem, just giving you the heads up :)
number on front is 49179-53
compressor wheel inlet is 5.5 cm...
looking into it, it seems it will to laggy for drift.
Last question, How many blades on the turbine wheel and measure the exducer on that as well.
P.S. the compressor inducer wouldn't be 52.7mm not 55 would it?
well i think it's an early version (judging by the compressor wheel) of a TD06SH-20G.
It'll be laggy as it's the biggest of the TD06's before you go to a T67. But it's a 330kw turbo.
It's too big for a 20 though, See you should have gone 25. ;)
Edited by D_Stirls
so for track purposes, its not really ideal eh?
im not scared to keep the revs up, and the extra tyre smoke would be kinda cool!
how would i go getting round the coolant lines? join them together?
edit: just seen your edit. i wont bother with it.....
what to get what to get??????????
Edited by craig R33
I'm not sure about that compressor wheel, i can't find anything that even looks close to it and it doesn't look like the current generation of 20G wheels although the inducer specs are very similar to the 20G size.
I have something perfect for you; BRB.
Edited by D_Stirls
Here you go it's a perfect turbo for a 20.
http://www.nissansilvia.com/forums/index.p...howtopic=414681.
You can get 300kw our of this turbo but 260-280kw is more reasonable.
And don't fore get that this is a $1800 turbo when it is new. You might want to change the turbine housing though.
EDIT!! Sorry missed the bit that said that it was sold.....lol
Edited by D_Stirls
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
